Hello,
I am trying to override the EDID of my dumb 4K TV to force RGB mode. I found a couple similar posts but none seemed resolved and they were older and talked about using mkinitcpio. It was mentioned that you need to force mkinitcpio to rebuild initramfs using the new EDID firmware file... but I haven't been able to find any equivalent way to do this with dracut. Maybe it does automatically? Either way the EDID is not changing. I changed the name of the monitor in the EDID to test it and it doesn't seem to change.
Here is my garuda-inxi output, and as you can see in my grub boot string I am using: drm.edid_firmware=HDMI-A-0:/edid/Samsung-EDID-RGB.bin ... I get no error but also no indication anything was loaded when I check dmesg. Thanks!
Kernel: 6.3.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw [email protected]
loglevel=3 drm.edid_firmware=HDMI-A-0:/edid/Samsung-EDID-RGB.bin ibt=off
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
UEFI: American Megatrends LLC. v: F24a date: 04/25/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x113
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 2988 high: 5248 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 3400 2: 2882 3: 3400
4: 801 5: 3400 6: 5248 7: 3400 8: 3400 9: 1229 10: 3400 11: 3400 12: 3400
13: 3400 14: 3400 15: 1748 16: 3400 17: 3400 18: 1218 19: 794 20: 3400
21: 3400 22: 3400 23: 3400 24: 3400 bogomips: 164044
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: XFX
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:73ef
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10.1:12
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10.3:15
chip-ID: 1532:0e03 class-ID: 0102
Device-4: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10.4:16 chip-ID: 534d:2109
Device-5: Elgato Systems GmbH Game Capture HD60 X
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-7.1:6
chip-ID: 0fd9:0082 class-ID: 0300 serial: <filter>
Device-6: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-9.2:8
chip-ID: 07ca:0110 class-ID: 0102 serial: <filter>
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung serial: <filter>
built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.0 renderer: AMD Radeon RX 6650 XT (navi23
LLVM 15.0.7 DRM 3.52 6.3.3-zen1-1-zen) direct-render: Yes
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
Device-4: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-5: MacroSilicon USB Video
Device-6: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-7: Focusrite-Novation Scarlett 4i4 USB driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
chip-ID: 1235:8212 class-ID: 0103 serial: <filter>
Device-8: Elgato Systems GmbH Game Capture HD60 X
Device-9: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.3.3-zen1-1-zen status: kernel-api with: aoss
Device-2: Aquantia vendor: Gigabyte driver: atlantic v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 2 port: N/A bus-ID: 06:00.0 chip-ID: 1d6a:14c0
class-ID: 0200 temp: 45.0 C
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14:13 chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 8.42 TiB used: 673.39 GiB (7.8%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 45.9 C scheme: GPT
fw-rev: 731100WD temp: 52.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
ID-5: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: X110 2.5 7MM 256GB
tech: SSD serial: <filter> fw-rev: 412 scheme: GPT
used: 166.3 GiB (17.9%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 2.7 MiB (0.9%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 62.62 GiB used: 1.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
mem: 42.0 C
Processes: 512 Uptime: 16m wakeups: 0 Memory: available: 62.62 GiB
used: 3.77 GiB (6.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1898
libs: 525 tools: octopi,paru,yay Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-05-03
Last full system update: 2023-05-24
