Help! Anyone knows of any mouse cursor lock to display software?
Big Linux noob here, apologies if this is the wrong place to ask this question
My situation and problem:
Im using a dual monitor display setup
Gaming becomes impossible without a reliable way of locking down the mouse cursor to the game output display
On my Windows 10 machine i solve this problem by using a program called "Dual monitor tools"
I tried running that program on here using wine but that doesn't work
I've been looking for a linux alternative and I can't seem to find anything except for a piece of software on the AUR called "jail" which I was unable to get working
Is there any software for this on linux? Specifically for locking the cursor to a particular monitor
garuda-inxi:
Kernel: 6.1.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ac3db51d-0458-4e6e-a36e-12defe2236f9 rw [email protected]
loglevel=3 ibt=off
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME A320I-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2203
date: 07/28/2020
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1634 high: 2800 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1337
3: 2800 4: 1270 5: 1550 6: 1550 7: 1303 8: 1354 9: 1279 10: 1270 11: 1550
12: 2800 bogomips: 81436
vendor: Sapphire Nitro+ driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DVI-D-1,
HDMI-A-1, HDMI-A-2 bus-ID: 07:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 47.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Monitor-1: DP-2 mapped: DisplayPort-1 model: VG259QM serial: <filter>
built: 2021 res: 1920x1080 dpi: 90 gamma: 1.2 size: 544x303mm (21.42x11.93")
diag: 623mm (24.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.11-zen1-1-zen) direct-render: Yes
vendor: Sapphire driver: snd_hda_intel v: kernel bus-ID: 3-2:3 pcie:
chip-ID: 041e:3256 class-ID: 0300 gen: 3 speed: 8 GT/s serial: <filter>
lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aaf0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
Device-3: Creative Sound BlasterX G6 type: USB
Sound API: ALSA v: k6.1.11-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 4.08 TiB used: 817.78 GiB (19.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37480G
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 56R8 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: Expansion HDD size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1901 scheme: GPT
used: 34.58 GiB (7.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.55 GiB used: 2.58 GiB (16.6%)
System Temperatures: cpu: 31.6 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 752
Processes: 401 Uptime: 10h 22m wakeups: 0 Memory: 15.55 GiB
used: 6.95 GiB (44.7%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1398
libs: 436 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.14-1):
System install date:     2023-02-13
Last full system update: 2023-02-13 ↻
Welcome to garuda
can you you provide your
as per the forum template
Is that an auto generated reply? Guess im posting on the wrong place
No...
We need your garuda-inxi output from a terminal in order to reply to support requests.
System info from it helps to know what desktop environment you are using, etc....
That cant be a safe thing to share can it? Sorry im genuinely not trolling
There are like 300 lines of system info there and IP stuff
I posted it and then deleted it that looked sketchy as hell
Please, thats not a chat forum. Edit your post until nobody answer.
Greetings SGS
If you looked at any support other thread, or even the template you deleted, this is a very common thing to ask. garuda-inxi is just our spin of a regular inxi( to see what the system is using) that are always used for support request. There is no IP information in there, you can look for yourself.
I will be back! The winds whisper my name
Welcome @normiedev01. Check this out:
https://www.uninformativ.de/git/xpointerbarrier/file/README.html
https://aur.archlinux.org/packages/xpointerbarrier-git
I will check up on those thanks man
I don't know if this applies to X11 too, on Sway/Wayland I use a very simple trick: I temporarily alter one monitor logical position so that they are not contiguous, and the mouse remains trapped.
