i am new to linux
the problem is that the audio from my pc inbuilt mic is comming properly
but the mic form my headset is not working
driver-pipeline
plz help need to attend online class
System: Kernel: 5.13.8-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=7112fee5-1db7-413b-85df-89fd133914fb
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Acer product: Swift SF314-55G v: V1.07 serial: <filter>
Mobo: WL model: MILLER_WL v: V1.07 serial: <filter> UEFI: American Megatrends v: 1.07
date: 12/24/2018
Battery: ID-1: BAT0 charge: 29.1 Wh (84.8%) condition: 34.3/48.9 Wh (70.0%) volts: 16.4 min: 15.2
model: AC14B8K type: Li-ion serial: N/A status: Charging
CPU: Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: B (11) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3703 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3703 2: 3747 3: 3744 4: 3082
5: 3752 6: 3732 7: 3539 8: 3591
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Acer Incorporated ALI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GP108BM [GeForce MX250] vendor: Acer Incorporated ALI driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:1d52 class-ID: 0302
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:5 chip-ID: 04f2:b5c5
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Acer Incorporated ALI
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0401
Sound Server-1: ALSA v: k5.13.8-zen2-1-zen running: yes
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 4000
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-10:6 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Drives: Local Storage: total: 476.94 GiB used: 16.55 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPNUW-512G-1014
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20110000 temp: 48.9 C scheme: GPT
Partition: ID-1: / raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 16.55 GiB (3.5%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 16.55 GiB (3.5%) fs: btrfs
ID-4: /var/log raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 16.55 GiB (3.5%) fs: btrfs
ID-5: /var/tmp raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 16.55 GiB (3.5%) fs: btrfs
ID-1: swap-1 type: zram size: 7.62 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 68.0 C mobo: N/A
Info: Processes: 316 Uptime: 25m wakeups: 2568 Memory: 7.62 GiB used: 3.6 GiB (47.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1406 lib: 400
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
