Headset/Headphone popup not appearing, mic not working
Hello. I’ve been using Arch Linux for a few weeks, but since the installation, my headset (3.5mm jack) is recognized as headphones and there’s no popup for asking if my device is a headset or headphones. I switched to Garuda GNOME Linux in hopes of maybe fixing the problem, but to no avail. I’ve tried the next fixes on both OSes:
hdajackretask
alsamixer
pavucontrol
Just to clarify, every app detects and picks up system output (stereo.monitor) instead of the actual mic.
If it helps, here’s my aplay -l output:
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC255 Digital [ALC255 Digital]
  Subdevices: 1/1
card 2: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 2: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 2: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
Here’s the garuda -inxi output, in case wasn’t seen in the replies:
[🔴] × garuda-inxi
  Kernel: 6.17.3-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=37bd38e4-8c7a-4ab4-bba4-5f82797bad5e rw rootflags=subvol=@
    quiet resume=UUID=6cde54ab-9550-4a95-a791-c3088b634721 loglevel=3
  Desktop: GNOME v: 49.1 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.1 Distro: Garuda base: Arch Linux
  Type: Laptop System: Acer product: Aspire E5-573G v: V3.72
  Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version
    serial: <superuser required> part-nu: Aspire E5-573G_098A_1_37
    uuid: <superuser required> UEFI: Insyde v: 1.37 date: 02/16/2016
  ID-1: BAT1 charge: 17.9 Wh (100%) condition: 17.9/37 Wh (48.3%) volts: 17.15
    min: 14.8 model: SANYO AL15A32 type: Li-ion serial: <filter> charging:
    status: full cycles: N/A
  Info: model: Intel Core i3-4005U bits: 64 type: MT MCP arch: Haswell
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1596 min/max: 800/1600 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1596 2: 1596 3: 1596 4: 1596 bogomips: 13568
  Device-1: Intel Haswell-ULT Integrated Graphics
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-7.5
    process: Intel 22nm built: 2013 ports: active: eDP-1 empty: DP-1,HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
  Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI
    driver: nouveau v: kernel non-free: series: 470.xx+
    status: legacy-active (EOL~2024-09-xx) arch: Kepler-2 code: GKxxx
    process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 04:00.0 chip-ID: 10de:1299
    class-ID: 0302 temp: 38.0 C
  Device-3: Sunplus Innovation HD WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 1bcf:2c81
    class-ID: 0e02
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x40ec built: 2013 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1366x768
  Info: Tools: x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Haswell-ULT HD Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
  Device-2: Intel 8 Series HD Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
  Device-3: NVIDIA GK208 HDMI/DP Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 04:00.1 chip-ID: 10de:0e0f
  API: ALSA v: k6.17.3-zen2-1-zen status: kernel-api
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4
    chip-ID: 04ca:3015 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.1
    lmp-v: 7 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 238.47 GiB used: 10.67 GiB (4.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDDAK256MAM-1K12
    tech: SSD serial: <filter> fw-rev: 09TH scheme: GPT
  ID-1: / raw-size: 229.38 GiB size: 229.38 GiB (100.00%)
    used: 10.67 GiB (4.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
    used: 632 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 229.38 GiB size: 229.38 GiB (100.00%)
  ID-4: /var/log raw-size: 229.38 GiB size: 229.38 GiB (100.00%)
  ID-5: /var/tmp raw-size: 229.38 GiB size: 229.38 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.67 GiB used: 12 KiB (0.0%) priority: 100
    dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 39.0 C
  Memory: total: 8 GiB available: 7.67 GiB used: 3.46 GiB (45.1%)
  Processes: 283 Power: uptime: 26m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.04 GiB services: gsd-power,
  Packages: pm: pacman pkgs: 1230 libs: 372 tools: paru Compilers:
    gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.2
    running-in: gnome-terminal inxi: 3.3.39
Garuda (2.11.1-1):
  System install date:     2025-10-20
  Garuda release:          251002
  Last full system update: 2025-10-20
  Is partially upgraded:   Yes
22/24 checks run in 2.58 seconds ⌛
Powered by garuda-health 🦅
--- CRITICAL ---
 - System is partially upgraded (fix available)
Any form of help is appreciated!!
I’ll respond to any messages as fast as I can. I’m desperate since my integrated mic sucks.
Post the terminal output of garuda-inxi as requested in the template for your post.
[🔴] × garuda-inxi
    class-ID: 0e02
Garuda (2.11.1-1):
--- CRITICAL ---
Very sorry, I am a bad reader. Don’t like waiting :frowning:
Hope this helps. Tell me if more is needed.
