Hello Garuda users.
So, the title is not clickbait. It really happens and i am soooo frickin' annoyed by this at this stage. I've hopped 2 distros in hopes this gets resolved and i can't even narrow the problem down. It just feels like a headphone problem but i need them to work fine like they do on windows and mobile phones.
I have Sony WH-CH710N headphones and what happens is if they are connected by bluetooth after a while, like if i am listening to songs on spotify and suddenly pause them to watch a youtube video for example, then the youtube video starts to buffers, and after 4-5 seconds, i head a "tick" in my headphones. the headphones don't respond to its own buttons after that. i have to switch it off and turn it back on and now they work and reconnect like nothing happened.
sudo journalctl -b || grep "blue" gives this input:
Dec 06 22:12:18 charismatic bluetoothd[459]: profiles/audio/avdtp.c:cancel_request() Start: Connection timed out (110)
Dec 06 22:12:18 charismatic wireplumber[376188]: Transport Acquire() failed for transport /org/bluez/hci0/dev_30_53_C1_67_B1_8C/sep2/fd
23 (Input/output error)
Dec 06 22:12:18 charismatic wireplumber[376188]: (bluez_output.30_53_C1_67_B1_8C.1-19) suspended -> error (Start error: Input/output er
ror)
Dec 06 22:12:20 charismatic bluetoothd[459]: profiles/audio/avdtp.c:cancel_request() Abort: Connection timed out (110)
Dec 06 22:12:20 charismatic dbus-daemon[460]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.444" (u
id=1000 pid=376188 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destinati
on=":1.5" (uid=0 pid=459 comm="/usr/lib/bluetooth/bluetoothd")
Dec 06 22:12:34 charismatic bluetoothd[459]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: ge
tpeername: Transport endpoint is not connected (107)
Dec 06 22:12:40 charismatic bluetoothd[459]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Dec 06 22:12:47 charismatic bluetoothd[459]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Dec 06 22:12:56 charismatic bluetoothd[459]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Dec 06 22:13:10 charismatic bluetoothd[459]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Dec 06 22:13:33 charismatic bluetoothd[459]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 30:53:C1:67:B1:8C: Connection refused (111)
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e58f8d48-2762-4f6b-917d-30452146592e rw [email protected]
resume=UUID=9b87b565-dc9a-49cd-a3ed-1ad68b237274 loglevel=3
Type: Laptop System: Hewlett-Packard product: HP ProBook 450 G2
v: A3008CD10003 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 2248 v: KBC Version 59.22
serial: <superuser required> BIOS: Hewlett-Packard v: M73 Ver. 01.14
date: 06/23/2015
ID-1: BAT0 charge: 0.0 Wh (0.0%) condition: 42.6/42.6 Wh (100.0%)
volts: 16.4 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2415 high: 2478 min/max: 500/2700 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2440 2: 2377 3: 2478
4: 2366 bogomips: 17559
vulnerable
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: AMD Topaz PRO [Radeon R5 M255] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 0a:00.0 chip-ID: 1002:6901
class-ID: 0380 temp: 51.0 C
Device-3: Lite-On HP HD Webcam type: USB driver: uvcvideo bus-ID: 2-7:4
chip-ID: 04ca:704d class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15be built: 2013 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
chip-ID: 8086:9ca0 class-ID: 0403
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
lanes: 1 port: 5000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 09:00.0 chip-ID: 10ec:b723
bus-ID: 2-4:2 chip-ID: 0bda:b001 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 6 state: up address: <filter>
Local Storage: total: 931.51 GiB used: 22.04 GiB (2.4%)
type: HDD rpm: 5400 serial: <filter> rev: LFM3 scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
used: 22.04 GiB (2.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-3: /var/log raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-4: /var/tmp raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.44 GiB used: 2.12 GiB (28.5%)
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 59.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Processes: 257 Uptime: 2d 9h 57m wakeups: 7 Memory: 7.44 GiB
used: 4.84 GiB (65.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: 1880 pm: pacman pkgs: 1862
libs: 519 tools: octopi,paru pm: flatpak pkgs: 18 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-12-03
Last full system update: 2022-12-06 ↻
Failed units: archlinux-keyring-wkd-sync.service
All i can deduce after months of this annoyance is that it maybe due to the usage of non-standard bluetooth protocols by my headphones but like is there any fix for it? maybe a new bluetooth adapter or something? Other than this it has been about 4-5 days on Garuda, And i must say this is sooooooo good, my boot time has just halved, everything feels snappier, lower memory usage and better kde experience than fedora kde spin that i was on ;p.
ALL OF YOUR HELP WILL BE HUGELY APPRECIATED.
