Headphone and SOUND ISSUE
Hello Garuda team
im facing a audio problem my sound output is imbalanced only WHEN CONNECTED TO HEADPHONES WIRED OR WIRELESS BOTH
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=2c334688-bc4c-489d-920e-7eaded5ffd93 rw rootflags=subvol=@
Type: Laptop System: Dell product: Latitude E7470 v: N/A
Mobo: Dell model: 0T6HHJ v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: 1.10.4 date: 11/04/2016
ID-1: BAT0 charge: 10.2 Wh (40.8%) condition: 25.0/55.0 Wh (45.5%)
volts: 7.5 min: 7.6 model: SMP DELL R97YT66 type: Li-poly serial: <filter>
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1549 high: 2086 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1340 2: 2086 3: 1359
4: 1413 bogomips: 19999
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell Latitude E7470
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Sunplus Innovation Dell Integrated HD Webcam type: USB
driver: uvcvideo bus-ID: 1-2:2 chip-ID: 1bcf:28bd class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x1036 built: 2014 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 2560x1440
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.1.0
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell Latitude E7470
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-LM vendor: Dell Latitude E7470 driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
Local Storage: total: 238.47 GiB used: 22.01 GiB (9.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: SC300 SATA 256GB
type: SSD serial: <filter> rev: 1P00 scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
used: 22.01 GiB (9.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-3: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.0 C pch: 51.0 C mobo: 49.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3335
Processes: 240 Uptime: 17h 47m wakeups: 22 Memory: 15.29 GiB
used: 3.62 GiB (23.7%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1141 lib: 291 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date:     2022-05-26
Last full system update: 2022-05-27 ↻
Is partially upgraded:   Yes
i searched wiki yet found nothing :slightly_frowning_face: ,
What have you tried so far?
Audio settings? External applications like pavucontrol? Etc...
ive tried balancing the audio tried working with replacing pipewire with pulseaudio (since pulseaudio did not connect to bluetooth ) reinstalled it back again dint work
plus : the thing only messes with the headphones or bluetooth devices of imbalanced sound , without any headphones and bluetooth devices the output ( speakers of laptop ) tht goes fine
additional information : when i test the audio with jamesDSP , the front right and front left is heard by only the left earphone and not right
