Hi, I'm using open-source drivers and when using xrandr, it just says that it cannot detect those outputs on my laptop. Thanks for all the help.
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=5411b7ff-d53c-4780-9b50-82a7b4183826 rw rootflags=subvol=@
Type: Laptop System: Acer product: Nitro AN515-57 v: V1.10
Mobo: TGL model: Scala_TLS v: V1.10 serial: <superuser required>
UEFI: Insyde v: 1.10 date: 09/19/2021
ID-1: BAT1 charge: 50.5 Wh (90.0%) condition: 56.1/57.5 Wh (97.6%)
volts: 16.5 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: discharging cycles: 164
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x3E
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1432 high: 1971 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1971 2: 979 3: 1654
4: 1186 5: 1492 6: 1545 7: 1159 8: 1387 9: 1689 10: 1658 11: 879 12: 1650
13: 1898 14: 1479 15: 1182 16: 1107 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 515.43.04
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Ampere bus-ID: 0000:01:00.0
chip-ID: 10de:25a2 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-9:3
chip-ID: 0408:a061 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.0
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
Sound Server-3: PulseAudio v: 16.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:43f0
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 2.29 TiB used: 691 GiB (29.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41020C20
temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-1: / raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
used: 273.94 GiB (92.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 50.5 MiB (52.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-4: /var/log raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-5: /var/tmp raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 870.8 MiB (5.5%)
System Temperatures: cpu: 27.8 C mobo: N/A
Processes: 384 Uptime: 11h 18m wakeups: 94 Memory: 15.41 GiB
used: 4.51 GiB (29.3%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1948 lib: 524 Shell: Bash
v: 5.1.16 running-in: terminator inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-02-16
Last full system update: 2022-06-03 ↻
