Hello community,
The HDMI port doesn't work on my pc. It also got an USB-C port for dock and screens work with it. But I must use the HDMI port.
After some search, I found that VBT is exposing the HDMI port as a eDP.
Luckly, I found a quick patch from this forum : HP Zbook Power 15 G9 (i7-12800H) HDMI not detected (#8601) · Issues · drm / intel · GitLab
But I can't understand how to install it.
Here's the garuda-inxi :
Kernel: 6.4.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=2d7fd863-a9ad-4263-a0a9-25ff0a30e5f8 rw rootflags=subvol=@
resume=UUID=4614172c-dce5-421b-81fe-e0a7b4eb480e loglevel=3 ibt=off
Type: Laptop System: HP product: HP ZBook Power 15.6 inch G9 Mobile
Workstation PC v: N/A serial: <superuser required> Chassis: type: 10
Mobo: HP model: 89C0 v: KBC Version 11.61.00 serial: <superuser required>
UEFI: HP v: U97 Ver. 01.07.01 date: 04/06/2023
ID-1: BAT0 charge: 62.7 Wh (98.4%) condition: 63.7/83.0 Wh (76.7%)
volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 110
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
microcode: 0x42A
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2605 high: 2700 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2700 3: 2700
4: 2700 5: 2700 6: 2700 7: 2700 8: 2700 9: 2700 10: 2700 11: 2700 12: 2700
13: 2700 14: 2700 15: 2700 16: 2700 17: 2700 18: 2700 19: 2700 20: 2700
bogomips: 107520
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:4626 class-ID: 0300
Device-2: NVIDIA TU117GLM [T600 Laptop GPU] vendor: Hewlett-Packard
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:1fb6
class-ID: 0302
Device-3: Chicony HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 04f2:b73b
Monitor-1: eDP-1 mapped: eDP-1-1 model-id: CSO 0x1506 built: 2021
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA T600 Laptop
GPU/PCIe/SSE2 direct-render: Yes
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.4.3-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
Device-2: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 476.94 GiB used: 20.19 GiB (4.2%)
model: MTFDKBA512TFH-1BC1AABHA size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS0043 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 459.86 GiB size: 459.86 GiB (100.00%)
used: 20.19 GiB (4.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.86 GiB size: 459.86 GiB (100.00%)
ID-4: /var/log raw-size: 459.86 GiB size: 459.86 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.86 GiB size: 459.86 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.79 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.26 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 381 Uptime: 23m wakeups: 20665 Memory: total: 16 GiB note: est.
available: 15.26 GiB used: 3.37 GiB (22.1%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1654 libs: 454 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-07-19
Last full system update: 2023-07-19
