Dear Garuda Users!
I haven’t found any issues like that in my last 5 years, so i turned to you.
My Special problem that my Laptop/NoteBook etc… Not giving signal on HDMI, but i have DP port on it and it’s working fine.
Things we got:
Nvidia app open + See that monitor
From Console/Log it sees that monitor too, but not giving signal
All Stuff Up to Date
Drivers working fine + Gaming + Virtualization as well
No Dual Boot
Fresh Operation system (only automount is modified)
Do you have any tips? Should i buy DP → HDMI converter?
Thanks for your future help!
garuda-inxi:
╭─naomi@naomi in ~
╰─λ garuda-inxi
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=10e1d259-4861-4fcf-8a02-1f09700b5773 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: MEDION product: Deputy P25 v: N/A
Mobo: MEDION model: NHxxEPx v: 1.0 serial: <superuser required>
UEFI: INSYDE v: 1.07.01RME1_00007 date: 06/04/2021
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1972 high: 3250 min/max: 400/4463 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 3169
4: 3168 5: 400 6: 3240 7: 3168 8: 400 9: 3179 10: 400 11: 3250 12: 3175
13: 3169 14: 400 15: 3242 16: 400 bogomips: 102219
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: CLEVO/KAPOK driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,DP-2,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
vendor: CLEVO/KAPOK driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-3,DP-4
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 45.0 C
Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04f2:b685
class-ID: 0e02
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: DP-1-2 res: 1920x1080 hz: 60 dpi: 93
Monitor-2: eDP pos: primary res: 1920x1080 hz: 144 dpi: 142
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.6.4-zen1-1-zen) device-ID: 1002:1638 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: NVIDIA GA106 High Definition Audio vendor: CLEVO/KAPOK
Device-2: AMD Renoir Radeon High Definition Audio vendor: CLEVO/KAPOK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: CLEVO/KAPOK
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
Device-4: AMD Family 17h/19h HD Audio vendor: MEDION AG
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api with: aoss
Device-2: Realtek RTL8125 2.5GbE vendor: CLEVO/KAPOK driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 2000 bus-ID: 05:00.0
IF-ID-1: enp6s0f3u1c4i2 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 8087:0029
Local Storage: total: 2.29 TiB used: 631.12 GiB (27.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 32.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVLB512HBJQ-00000 size: 476.94 GiB block-size: physical: 512 B
fw-rev: EXF7201Q temp: 27.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A scheme: MBR
used: 604.76 GiB (64.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 14.99 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 62.8 C mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 376 Uptime: 14m wakeups: 0 Memory: total: 16 GiB note: est.
available: 14.99 GiB used: 4.53 GiB (30.2%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: 2034 pm: dpkg pkgs: 1 pm: pacman pkgs: 2033
libs: 573 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.2
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-10-29
Last full system update: 2023-12-09
