Having trouble uninstalling CQRLOG
Ok I have installed CQRLOG on my computer and messed it up. So I would like to uninstall it and reinstall it. My problem is using the pacman command doesn’t seem to be working. Any help would be great.
please follow the Template and post your garuda-inxi output here to get assistance. </> sign on chat symbols or put abve and below three ~~~.
how did you installed it?
And always consider
havn’t setup snapshots yet.
with Terminal..
Snapshots are configured by default to be generated before and after each installation and update.
So, going back to the initial question from @Duke187 , we need to understand how (from where, the AUR package? which one?) you installed it.
Please be precise in your answers and provide as much information as possible.
For me, for an issue related to the installation of a package, I’d specify at least the precise package name, release, source, and method (Terminal is clear, but from terminal you can install an Arch package with pacman, an AUR package with paru or compiling it, etc.).
I noticed now:
In this case and similar, always provide the exact terminal input and output, for the helpers to check.
And, again, garuda-inxi is missing.
It is required in the topic template, and sometimes it includes important information that might not seem related at first.
