done the upd and update, no issues; also sorry but where do I get garuda-inix log at nvm figured it out
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LC_MONETARY = "en_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_MEASUREMENT = "en_US.UTF-8",
LC_TIME = "en_US.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=4f64013a-7f46-4dc0-a552-be58d9224a85 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5003 date: 10/07/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3452 high: 3640 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3600
3: 3600 4: 3600 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3640
12: 3400 13: 3400 14: 3400 15: 3400 16: 3400 bogomips: 108801
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0b:00.0
chip-ID: 10de:2684 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.7
Screen-1: 0 s-res: 5120x1440 s-dpi: 80 s-size: 1626x457mm (64.02x17.99")
s-diag: 1689mm (66.5")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: Samsung LC49G95T
serial: <filter> built: 2020 res: 5120x1440 hz: 240 dpi: 130048 gamma: 1.2
size: 1x1mm (0.04x0.04") diag: 1239mm (48.8") modes: max: 3840x1080
min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 550.78 device-ID: 10de:2684
surfaces: xcb,xlib
Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0b:00.1 chip-ID: 10de:22ba class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone
lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: b58e:9e84 class-ID: 0300
Device-4: Cambridge Silicon Radio Mpow HC5 Headset in charging mode - HID
/ Mass Storage driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-4.1.1:6 chip-ID: 0a12:4007
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5:3
Local Storage: total: 15.46 TiB used: 1.16 TiB (7.5%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN850X 4000GB size: 3.64 TiB block-size: physical: 512 B
fw-rev: 624311WD temp: 53.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 45.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN008-2DR166
tech: HDD rpm: 5980 serial: <filter> fw-rev: SC60 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD2003FZEX-00SRLA0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.16 TiB (31.9%)
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 1.16 TiB (31.9%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 78.8 MiB (0.2%)
System Temperatures: cpu: 47.2 C mobo: N/A gpu: nvidia temp: 43 C
Memory: total: 32 GiB available: 31.25 GiB used: 5.72 GiB (18.3%)
Processes: 443 Power: uptime: 4h 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1888 libs: 539 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-05-10
Last full system update: 2024-05-17 ↻
