Having some CUPS issues with Broadwing Dr4gonized Gaming
I am having some issues with CUPS not loading my USB laser printer. I have no issues with it running on vanilla arch. It doesn’t show when I run “lpstat” but does list with the USB devices. When I run lpstat -d all I get is “no system default destination”. have to admit I am no CUPS expert so this has me a bit baffled.
Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a9ca0395-8040-4a20-a513-f916a4c04829 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
Megatrends LLC. v: 1.I0 date: 07/13/2024
Info: model: AMD Ryzen 9 5900XT bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1737 min/max: 550/4980 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1737 2: 1737 3: 1737
4: 1737 5: 1737 6: 1737 7: 1737 8: 1737 9: 1737 10: 1737 11: 1737 12: 1737
13: 1737 14: 1737 15: 1737 16: 1737 17: 1737 18: 1737 19: 1737 20: 1737
21: 1737 22: 1737 23: 1737 24: 1737 25: 1737 26: 1737 27: 1737 28: 1737
29: 1737 30: 1737 31: 1737 32: 1737 bogomips: 211204
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Sapphire driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2,
HDMI-A-1, Writeback-1 bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: AOC Q34G2G5 serial: <filter> built: 2020 res:
mode: 2560x1080 hz: 75 scale: 100% (1) dpi: 82 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 2560x1080
min: 720x400
navi22 LLVM 19.1.7 DRM 3.61 6.13.5-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.4.304 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: N/A device-ID: 1002:73df
de: kscreen-console,kscreen-doctor gpu: amd-smi,corectrl wl: wayland-info
bus-ID: 2d:00.1 chip-ID: 1002:ab28 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Textech USB Midi 4i4o driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10.1:16 chip-ID: 15ca:1804
class-ID: 0103
Device-4: BEHRINGER GmbH WASP DELUXE driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10.2:9
chip-ID: 1397:1222 class-ID: 0103 serial: <filter>
Device-5: Thomann SWISSONIC EasyKeys49 driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10.4.1:12
chip-ID: 07fc:1111 class-ID: 0103
Device-6: Razer USA RC30-026902 Gaming Headset [Nari Essential Wireless
Receiver] driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10.4.2:13 chip-ID: 1532:051e
Device-7: BEHRINGER GmbH UMC204HD 192k driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 1397:0508
class-ID: fe01
API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api with: aoss
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:10
Local Storage: total: 6.39 TiB used: 1.27 TiB (19.9%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Realtek model: nvme1T
lanes: 4 tech: SSD serial: <filter> fw-rev: VC2S0388 temp: 35.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHGP31-1000GM size: 931.51 GiB block-size: physical: 512 B
fw-rev: 41062C20 temp: 35.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC
tech: SSD serial: <filter> fw-rev: 20RL scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA200
tech: HDD rpm: 7200 serial: <filter> fw-rev: ABB0 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1002 scheme: GPT
ID-1: / raw-size: 442.56 GiB size: 442.56 GiB (100.00%)
used: 208.64 GiB (47.1%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:3
used: 371.1 MiB (36.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 442.56 GiB size: 442.56 GiB (100.00%)
ID-4: /var/log raw-size: 442.56 GiB size: 442.56 GiB (100.00%)
ID-5: /var/tmp raw-size: 442.56 GiB size: 442.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.71 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
System Temperatures: cpu: 38.2 C mobo: N/A gpu: amdgpu temp: 37.0 C
mem: 32.0 C
Memory: total: 64 GiB note: est. available: 62.71 GiB used: 6.13 GiB (9.8%)
Processes: 589 Power: uptime: 5h 18m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.07 GiB services: org_kde_powerdevil,
Packages: 1988 pm: pacman pkgs: 1982 libs: 580 tools: octopi,paru
pm: flatpak pkgs: 6 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.0 running-in: konsole inxi: 3.3.37
System install date:     2025-03-08
Last full system update: 2025-03-09 ↻
USB Device List “brother” printer is listed:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 04f3:152e Elan Microelectronics Corp. Gaming KB
Bus 001 Device 004: ID 1397:0508 BEHRINGER International GmbH UMC204HD 192k
Bus 001 Device 005: ID 1462:7c56 Micro Star International MYSTIC LIGHT
Bus 001 Device 006: ID 1038:160e SteelSeries ApS SteelSeries Apex 100 Gaming Keyboard
Bus 001 Device 007: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 009: ID 1397:1222 BEHRINGER International GmbH WASP DELUXE
Bus 001 Device 010: ID 3938:1191  2.4G Wireless Mouse
Bus 001 Device 011: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 012: ID 07fc:1111 Thomann SWISSONIC EasyKeys49
Bus 001 Device 013: ID 1532:051e Razer USA, Ltd RC30-026902, Gaming Headset [Nari Essential, Wireless, Receiver]
Bus 001 Device 014: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 015: ID 046d:c08b Logitech, Inc. G502 SE HERO Gaming Mouse
Bus 001 Device 016: ID 15ca:1804 Textech International Ltd. USB Midi 4i4o
Bus 001 Device 017: ID 04f9:0090 Brother Industries, Ltd HL-L8260CDW series
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 010: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 003 Device 011: ID 231d:0204 VKB-Sim (C) Alex Oz 2023  VKBsim Gladiator NXT R SEM
Bus 003 Device 014: ID 231d:0201 VKB-Sim (C) Alex Oz 2023  VKBsim Gladiator NXT L
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Driver installed? If not:
paru -S brother-hl-l8260cdw
reboot and check again.
to check: systemctl status cups
if the service is runnung
open browser :
http://localhost:631/admin
There you can config your printer/s.
If not: make cups active over sysctl, Garuda-Assistent.
Cups is running. I installed the driver. I installed the printer through ipp. still gots no prints. When I run lpinfo it doesn’t list it.
● cups.service - CUPS Scheduler
Loaded: loaded (/usr/lib/systemd/system/cups.service; enabled; preset: disabled)
Active: active (running) since Sun 2025-03-09 12:37:46 MDT; 22min ago
Invocation: 13cc8bb947ad42d98be409c8c5c20361
TriggeredBy: ● cups.socket
● cups.path
Docs: man:cupsd(8)
Main PID: 1531 (cupsd)
Status: "Scheduler is running..."
Tasks: 1 (limit: 76926)
Memory: 185.6M (peak: 323.7M)
CPU: 10.677s
CGroup: /system.slice/system-cups.slice/cups.service
└─1531 /usr/bin/cupsd -l
Mar 09 12:37:46 Isadora2 systemd[1]: Starting CUPS Scheduler...
Mar 09 12:37:46 Isadora2 systemd[1]: Started CUPS Scheduler.
╭─scott@Isadora2 in ~/Documents took 0s
╰─λ lpstat -d
system default destination: Brother-HL-L8260CDW
╰─λ lpinfo -v
network beh
file cups-pdf:/
network http
network https
network ipps
network ipp
network lpd
network socket
network smb
on other thing. when I try to print a test page the Print Settings freezes up.
and then ?
I get the cups admin page and have added the printer through that too. but still no printing. When I have it list available printers I get nothing.
Garuda-Assistent show this ?
Firewall active ?
I checked the boxes and updated via garuda-update. so maybe that will do it?
and now garuda update has been running for over 10 minutes…is this normal?
First, reboot your system, pls.
Well, that´s mokka with rani or dragon with rani or ?
Rani, for me is “under construction”.
Special printing/scanning stuff. (perhaps only on my system)
Can you see your printer via KDE settings?
dragon. If the printer support box is unchecked is that an issue? as I can’t get Rani to work. Is there a command in cli for the garuda-update to install support? Reboot did it this time!
We always mark here the solution and not the implementation.
I fix it for you :slight_smile:
