Hello everyone, I ran into such a problem, everything was ok before, but after updating the system, I can’t start games and Steam, here’s an error
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 151 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 253
Current serial number in output stream: 254
Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=47c92427-6acd-4e9b-b163-3b09dcb2dd92 rw rootflags=subvol=@
Desktop: bspwm v: 0.9.10 info: polybar vt: 2 dm: SDDM Distro: Garuda Linux
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: H61M-S1 v: x.x serial: <superuser required>
BIOS: American Megatrends v: F5 date: 03/23/2012
Info: model: Intel Xeon E3-1245 V2 bits: 64 type: MT MCP arch: Ivy Bridge
level: v2 built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58)
stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1902 high: 3800 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1600 3: 1600
4: 1600 5: 3800 6: 1600 7: 1824 8: 1600 bogomips: 54276
Device-1: NVIDIA GK107 [GeForce GT 640] vendor: Palit Microsystems
driver: nvidia v: 470.182.03 alternate: nouveau,nvidia_drm non-free: N/A
status: unknown device ID pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:0fc1 class-ID: 0300
compositor: Picom v: git-c4107 driver: X: loaded: nvidia gpu: nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 30 s-size: 1626x914mm (64.02x35.98")
s-diag: 1865mm (73.44")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 30
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.27") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 470.182.03 renderer: NVIDIA GeForce GT
640/PCIe/SSE2 direct-render: Yes
vendor: Gigabyte 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GK107 HDMI Audio vendor: Palit Microsystems
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
IF-ID-1: wlp0s29u1u6 state: up mac: <filter>
Local Storage: total: 1.16 TiB used: 121.63 GiB (10.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: KingSpec model: P4-240
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 873 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DL002-9TT153
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CC3C scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 model: USB DISK 2.0 size: 28.91 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 458.35 GiB size: 458.35 GiB (100.00%)
used: 121.63 GiB (26.5%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-2: /home raw-size: 458.35 GiB size: 458.35 GiB (100.00%)
ID-3: /var/log raw-size: 458.35 GiB size: 458.35 GiB (100.00%)
ID-4: /var/tmp raw-size: 458.35 GiB size: 458.35 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.72 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Processes: 248 Uptime: 29m wakeups: 0 Memory: available: 7.72 GiB
used: 3.14 GiB (40.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: 1622 pm: pacman pkgs: 1611
libs: 485 tools: pamac,paru,yay pm: flatpak pkgs: 11 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.27
System install date: 2023-03-21
Last full system update: 2023-07-09
