Hey everyone,
I have recently installed garuda sway for a minimial and power efficient desktop. I have been learning and tweaking this for almost 3 days now and I am having too many issues that I feel I should go back to arch linux with hyprland. However i dont wanna lose hope and community seems to be my last hope. I will post my other issues in further posts. For now, the display issue…
For some reason, the display manager isn’t saving the configuration after reboot. I set the resolution of my laptop display to be 1680x1050 (because everything seems too tiny) and after reboot, it resets back to 2240x1400.
And also another question. I would like to have my configuration such that when i connect my laptop to a hdmi monitor, my main laptop display turns off and my hdmi monitor is the main display now and when i disconnect the hdmi, the laptop display turns back to normal. I have tried many things (including writing .sh file thru chatgpt and adding it in .config/sway/scripts and calling the script in autostart-applications file). Each time i refine it, it would break something else.
Is there any solution for these? (I have tried searching abt this in forum and didnt find anything)
Thanks in advance!
Kernel: 6.14.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f7a1bd70-67e6-43b9-9ba8-616f8ef92b8d rw rootflags=subvol=@
quiet loglevel=3 hush ibt=off
Desktop: Sway v: 0.5 with: waybar tools: swayidle avail: gtklock vt: 1
lm: greetd Distro: Garuda base: Arch Linux
Type: Convertible System: LENOVO product: 82XX v: IdeaPad Flex 5 14ABR8
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14ABR8
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> part-nu: LENOVO_MT_82XX_BU_idea_FM_IdeaPad
Flex 5 14ABR8 uuid: <superuser required> UEFI: LENOVO v: L7CN23WW
date: 09/10/2024
ID-1: BAT0 charge: 42.3 Wh (79.1%) condition: 53.5/52.5 Wh (102.0%)
power: 10.8 W volts: 12.1 min: 11.5 model: LGES L21L3PE0 type: Li-poly
serial: <filter> status: discharging cycles: 560
Info: model: AMD Ryzen 7 7730U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500011
Speed (MHz): avg: 400 min/max: 400/2000 boost: disabled scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 63877
Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Lenovo
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 42.0 C
Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 30c9:0053
Display: wayland server: Xwayland v: 24.1.6 compositor: Sway v: 0.5
driver: gpu: amdgpu d-rect: 3360x1050 display-ID: 1
Monitor-1: HDMI-A-1 pos: primary,left model: Acer V223W serial: <filter>
built: 2008 res: mode: 1680x1050 hz: 60 scale: 100% (1) dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
Monitor-2: eDP-1 pos: right model: Lenovo 0x89bc built: 2020 res:
mode: 1680x1050 hz: 60 scale: 100% (1) dpi: 190 gamma: 1.2
size: 300x188mm (11.81x7.4") diag: 354mm (13.9") ratio: 16:10 modes:
max: 2240x1400 min: 640x480
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:15e7
Info: Tools: api: vulkaninfo wl: kanshi, swaymsg, wdisplays, wlr-randr
x11: xprop
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.1-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4853
Report: btmgmt ID: hci0 rfk-id: 5 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 953.87 GiB used: 10.11 GiB (1.1%)
model: MZAL41T0HBLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 7L1QHXC7 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 147.43 GiB size: 147.43 GiB (100.00%)
used: 10.11 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 1 GiB size: 1 GiB (99.80%) used: 608 KiB (0.1%)
fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-3: /home raw-size: 147.43 GiB size: 147.43 GiB (100.00%)
ID-4: /var/log raw-size: 147.43 GiB size: 147.43 GiB (100.00%)
ID-5: /var/tmp raw-size: 147.43 GiB size: 147.43 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.97 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.9 C mobo: N/A gpu: amdgpu temp: 42.0 C
Memory: total: 16 GiB note: est. available: 14.97 GiB used: 4.61 GiB (30.8%)
Processes: 378 Power: uptime: 3h 35m states: freeze,mem,disk
suspend: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 5.98 GiB services: upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1171 libs: 358 tools: pacseek,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1 running-in: foot
inxi: 3.3.37
System install date: 2025-04-09
Last full system update: 2025-04-09
