Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=37536d2b-56c7-4224-bd6a-a48d164c6ef7 rw [email protected]
intel_iommu=on iommu=pt systemd.unified_cgroup_hierarchy=0
Type: Desktop Mobo: MEDION model: B560H6-EM v: 1.0 serial: <filter>
UEFI: American Megatrends v: 560H6W0X.019 date: 07/12/2021
Info: model: 11th Gen Intel Core i5-11400 socket: U3E1 bits: 64
type: MT MCP arch: Rocket Lake family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x50
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3895 high: 4382 min/max: 800/4400 base/boost: 4158/4400
scaling: driver: intel_pstate governor: performance volts: 1.2 V
ext-clock: 100 MHz cores: 1: 4213 2: 3908 3: 4065 4: 3769 5: 3489 6: 4382
7: 3529 8: 2759 9: 3728 10: 4243 11: 4313 12: 4351 bogomips: 62208
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: ZOTAC driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2503 class-ID: 0300
Device-2: SHENZHEN EMEET HD Webcam C960 type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 1-5:5
chip-ID: 328f:2013 class-ID: 0300 serial: <filter>
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 90 s-size: 1084x301mm (42.7x11.9")
s-diag: 1125mm (44.3")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Monitor-2: DP-2 pos: primary,right res: 1920x1080 dpi: 90
size: 544x303mm (21.4x11.9") diag: 623mm (24.5")
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: MEDION AG
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 0c76:161e
Device-4: SHENZHEN EMEET HD Webcam C960 type: USB
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
vendor: MEDION AG driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 982.7 GiB used: 532.08 GiB (54.1%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
rev: GXA7301Q temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 17d 23h cycles: 213
read-units: 15,274,953 [7.82 TB] written-units: 18,056,507 [9.24 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 28.83 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1100 scheme: MBR
used: 532.08 GiB (55.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 57 C
Processes: 371 Uptime: 2h 54m wakeups: 0 Memory: 15.5 GiB
used: 8.81 GiB (56.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1912 pacman: 1906 lib: 547 flatpak: 6
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-01-10
Last full system update: 2022-03-09
Failed units: memavaild.service systemd-oomd.socket
I've tried using pulse audio and not using pulse audio but the issue seems to persist, and it's quite inconsistent it's not like cutting out constantly, but the interval and frequency seems to change for no apparent reason. Lmao not even sure how to approach this issue, anyone else experiencing this? I've been having the issue since I started using garuda, so it's been quite a while.
