So recently i tried running and installing grapejuice when i ran it for the first time i ran into an error.
File "/usr/lib/python3.11/site-packages/grapejuice_common/util/pydantic_loader.py", line 3, in <module>
from pydantic import v1
ModuleNotFoundError: No module named 'pydantic'
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.11/site-packages/grapejuice/cli/cli_common.py", line 78, in wrapper
common_prepare()
File "/usr/lib/python3.11/site-packages/grapejuice/cli/cli_common.py", line 59, in common_prepare
from grapejuice_common.features.settings import current_settings
File "/usr/lib/python3.11/site-packages/grapejuice_common/features/settings.py", line 8, in <module>
from grapejuice_common.hardware_info import hardware_profile
File "/usr/lib/python3.11/site-packages/grapejuice_common/hardware_info/hardware_profile.py", line 17, in <module>
from grapejuice_common.util.pydantic_loader import pydantic_v1
File "/usr/lib/python3.11/site-packages/grapejuice_common/util/pydantic_loader.py", line 7, in <module>
import pydantic
I searched everywhere but couldn’t Seem to find a solution…
Here is the Garuda-inxi
╰─λ garuda-inxi
Kernel: 6.8.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=25376516-84e0-46d7-86bc-264dac89496b rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: Dell product: Vostro 3501 v: N/A
Mobo: Dell model: 0790WT v: A00 serial: <superuser required> part-nu: 0A2A
uuid: <superuser required> UEFI: Dell v: 1.11.0 date: 12/15/2021
ID-1: BAT0 charge: 31.2 Wh (100.0%) condition: 31.2/42.0 Wh (74.3%)
volts: 12.6 min: 11.4 model: SMP DELL VM73283 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC4
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 704 high: 1100 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 919 2: 400 3: 1100 4: 400
bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Dell driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4
chip-ID: 1bcf:2b98 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.5
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 338x190mm (13.31x7.48")
s-diag: 388mm (15.27")
Monitor-1: eDP-1 model: BOE Display 0x08cd built: 2019 res: 1280x720
hz: 60 dpi: 95 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 11.19 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 24.0.4-arch1.2
device-ID: 8086:8a56 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.4-arch1.2 (LLVM
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.8.4-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
vendor: Dell RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 0cf3:e009
Local Storage: total: 931.51 GiB used: 53 GiB (5.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 01 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 53 GiB (5.7%)
used: 600 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
used: 53 GiB (5.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 11.46 GiB used: 797.2 MiB (6.8%)
System Temperatures: cpu: 54.0 C mobo: 40.0 C
Fan Speeds (rpm): cpu: 2938
Memory: total: 12 GiB note: est. available: 11.46 GiB used: 5.45 GiB (47.6%)
Processes: 238 Power: uptime: 17h 53m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 4.54 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1520 libs: 422 tools: octopi,paru,yay
Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
Garuda (2.6.24-1):
System install date: 2022-12-26
Last full system update: 2024-04-07
dawe
8 April 2024 13:31
3
Try installing the python-pydantic package, then see what it does.
Can you please send the code on how to install the package please? I am still learning the basic commands…
nepti
8 April 2024 15:18
5
sudo pacman -S python-pydantic python-pydantic-core python-pydantic-settings python-pydantic-extra-types
Thank you so much! Now my grapejuice is running
nepti
8 April 2024 16:23
7
Please mark the post from @dawe
as the solution, not mine.
system
Closed
10 April 2024 16:23
8
