Garuda-inxi
root=UUID=e10452ba-7cf4-4aae-b664-034eb95fe7c0 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Hewlett-Packard product: HP Compaq Pro 6300 MT v: N/A
serial: Chassis: type: 6 serial:
Mobo: Hewlett-Packard model: 339A serial:
UEFI: Hewlett-Packard v: K01 v02.90 date: 07/16/2013
ID-1: hidpp_battery_0 charge: 96% condition: N/A volts: 4.1 min: N/A
model: Logitech G915 TKL LIGHTSPEED Wireless RGB Mechanical Gaming Keyboard
type: N/A serial: status: full
ID-2: hidpp_battery_1 charge: 29% condition: N/A volts: 3.7 min: N/A
serial: status: discharging
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2174 high: 3900 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3900 2: 1596 3: 1600
4: 1600 5: 1600 6: 1600 7: 3900 8: 1600 bogomips: 54279
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 535.113.01
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.9 driver: X: loaded: modesetting,nvidia
s-diag: 583mm (22.95")
Monitor-1: DVI-D-0 pos: primary res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: N/A
Monitor-2: None-1-1 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 535.113.01
device-ID: 10de:1f82 surfaces: xcb,xlib
vendor: Hewlett-Packard 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502
IF: eno1 state: down mac:
IF: wlp3s0 state: up mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.6:3 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.59 TiB used: 6.36 GiB (0.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: BarraCuda 120 SSD
ZA250CM10003 size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: fw-rev: D013 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 1T00
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: fw-rev: 00RL scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT500P3S SD8
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial:
fw-rev: 5102 scheme: GPT
used: 6.36 GiB (1.4%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 40%
Processes: 304 Uptime: 11m wakeups: 5 Memory: total: 16 GiB
available: 15.57 GiB used: 2.22 GiB (14.3%) Init: systemd v: 254
pm: pacman pkgs: 1341 libs: 442 tools: paru Shell: fish v: 3.6.1
running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-12-03
Last full system update: 2023-12-03
Is partially upgraded: Yes
so if i start the system Update with the Garuda Assistent than i get this error
→ Refreshing mirrorlists using rate-mirrors, please be patient…![]()
:: Paketdatenbanken werden synchronisiert …
garuda wird heruntergeladen …
core wird heruntergeladen …
extra wird heruntergeladen …
multilib wird heruntergeladen …
chaotic-aur wird heruntergeladen …
:: Starting full system upgrade…
:: Replace mhwd-db-garuda-git with garuda/mhwd-db-garuda? [Y/n] y
:: Replace sweet-kde-theme-git with chaotic-aur/plasma5-themes-sweet-kde-git? [Y/n] y
resolving dependencies…
looking for conflicting packages…
:: removing sweet-kde-theme-git breaks dependency ‘sweet-kde-theme-git’ required by sweet-theme-full-git
Press enter to exit
so what can i do, to fix this error
