Hello dear Garuda team,
Mandatory inxi output below:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=58b8aaef-a830-4cca-ae78-c267c6a7f5c6 rw rootflags=subvol=@
resume=UUID=4fecc35c-65fa-4061-8faa-890a1889740f loglevel=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Desktop Mobo: Micro-Star
model: MPG X570 GAMING PRO CARBON WIFI (MS-7B93) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.60
date: 01/14/2020
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3728 high: 4235 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4235 2: 3610
3: 3776 4: 3599 5: 3590 6: 3600 7: 3649 8: 3778 9: 4149 10: 3598 11: 3570
12: 3592 bogomips: 91202
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Gigabyte
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 2d:00.0
chip-ID: 10de:1f06 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 542x301mm (21.34x11.85")
s-diag: 620mm (24.41")
Monitor-1: DP-2 res: 1920x1080 dpi: 90 size: 540x300mm (21.26x11.81")
diag: 618mm (24.32") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 510.68.02 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Gigabyte
bus-ID: 2d:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: ip_vti0 state: down mac: <filter>
bus-ID: 1-4:2 chip-ID: 8087:0029 class-ID: e001
address: N/A
Local Storage: total: 3.75 TiB used: 79.51 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
rev: 2B2QEXM7 temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
model: WD1002FAEX-00Y9A0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1D05
scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 115.48 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 448.37 GiB size: 448.37 GiB (100.00%)
used: 79.51 GiB (17.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 448.37 GiB size: 448.37 GiB (100.00%)
ID-4: /var/log raw-size: 448.37 GiB size: 448.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.37 GiB size: 448.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.63 GiB used: 5.2 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 49%
Processes: 408 Uptime: 5h 32m wakeups: 0 Memory: 15.63 GiB
used: 9.72 GiB (62.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1985 lib: 532 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2021-10-15
Last full system update: 2022-05-05 ↻
Failed units: grub-btrfs-snapper.path grub-btrfs-snapper.service
Problem description:
I had arbtt installed on my system and ran fine until today. After the last update i get the error:
arbtt-stats: error while loading shared libraries: libHSutf8-string-1.0.2-FOQgGpXm4p2BxMMm2pyYrn-ghc9.0.2.so: cannot open shared object file: No such file or directory
I checked the /usr/lib folder and the file name has changed after the update:
✦ [🔍] × ls /usr/lib | grep libHS | grep utf8
.rwxr-xr-x 301k root 4 mai 13:02 libHSutf8-string-1.0.2-9eFA57BgKXNHtjvfuIOq9f-ghc9.0.2.so
Same lib but a change in what i think is some sort of hash embedded in the file name. Changed on my last system update yesterday. Ok.
The extent to which I am missing libs required to run arbtt is the following:
ldd /usr/bin/arbtt-capture
linux-vdso.so.1 (0x00007ffcb1d77000)
libHSutf8-string-1.0.2-FOQgGpXm4p2BxMMm2pyYrn-ghc9.0.2.so => not found
libHSdirectory-1.3.6.2-ghc9.0.2.so => /usr/lib/ghc-9.0.2/directory-1.3.6.2/libHSdirectory-1.3.6.2-ghc9
.0.2.so (0x00007ff269505000)
libHSfilepath-1.4.2.1-ghc9.0.2.so => /usr/lib/ghc-9.0.2/filepath-1.4.2.1/libHSfilepath-1.4.2.1-ghc9.0.
2.so (0x00007ff2694d2000)
libHSaeson-1.5.6.0-C19GJXDSM92LJPi4EK7PL5-ghc9.0.2.so => not found
libHSvector-0.12.3.1-2b175nNx5wND5qcnREemcu-ghc9.0.2.so => not found
libHSunordered-containers-0.2.18.0-5g7cvfJKetKCmnCFTnDbJb-ghc9.0.2.so => not found
libHSstrict-0.4.0.1-D6E5Iy4FuekGyXGwauQsyA-ghc9.0.2.so => not found
libHSunix-2.7.2.2-ghc9.0.2.so => /usr/lib/ghc-9.0.2/unix-2.7.2.2/libHSunix-2.7.2.2-ghc9.0.2.so (0x0000
7ff2693b9000)
libHStime-1.9.3-ghc9.0.2.so => /usr/lib/ghc-9.0.2/time-1.9.3/libHStime-1.9.3-ghc9.0.2.so (0x00007ff269
1f5000)
libHSscientific-0.3.7.0-2ciLBdxk3PkJ1Ff6Knc9zj-ghc9.0.2.so => not found
libHShashable-1.4.0.1-4LYnLqhVCzaKURVgzlvekc-ghc9.0.2.so => not found
libHStext-1.2.5.0-ghc9.0.2.so => /usr/lib/ghc-9.0.2/text-1.2.5.0/libHStext-1.2.5.0-ghc9.0.2.so (0x0000
7ff268f40000)
libHSbinary-0.8.8.0-ghc9.0.2.so => /usr/lib/ghc-9.0.2/binary-0.8.8.0/libHSbinary-0.8.8.0-ghc9.0.2.so (
0x00007ff268e2f000)
libHScontainers-0.6.4.1-ghc9.0.2.so => /usr/lib/ghc-9.0.2/containers-0.6.4.1/libHScontainers-0.6.4.1-g
hc9.0.2.so (0x00007ff2689b9000)
libHSbytestring-0.10.12.1-ghc9.0.2.so => /usr/lib/ghc-9.0.2/bytestring-0.10.12.1/libHSbytestring-0.10.
12.1-ghc9.0.2.so (0x00007ff268877000)
libHSX11-1.10.2-KQy9vQgF7qz18AG53z4Erf-ghc9.0.2.so => /usr/lib/libHSX11-1.10.2-KQy9vQgF7qz18AG53z4Erf-
ghc9.0.2.so (0x00007ff2685c1000)
libHSbase-4.15.1.0-ghc9.0.2.so => /usr/lib/ghc-9.0.2/base-4.15.1.0/libHSbase-4.15.1.0-ghc9.0.2.so (0x0
0007ff2678aa000)
libHSghc-bignum-1.1-ghc9.0.2.so => /usr/lib/ghc-9.0.2/ghc-bignum-1.1/libHSghc-bignum-1.1-ghc9.0.2.so (
0x00007ff26783b000)
libHSghc-prim-0.7.0-ghc9.0.2.so => /usr/lib/ghc-9.0.2/ghc-prim-0.7.0/libHSghc-prim-0.7.0-ghc9.0.2.so (
0x00007ff2672f7000)
libHSrts-ghc9.0.2.so => /usr/lib/ghc-9.0.2/rts/libHSrts-ghc9.0.2.so (0x00007ff267273000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007ff26712f000)
libc.so.6 => /usr/lib/libc.so.6 (0x00007ff266f25000)
libHSdeepseq-1.4.5.0-ghc9.0.2.so => /usr/lib/ghc-9.0.2/directory-1.3.6.2/../deepseq-1.4.5.0/libHSdeeps
eq-1.4.5.0-ghc9.0.2.so (0x00007ff266efd000)
libHSarray-0.5.4.0-ghc9.0.2.so => /usr/lib/ghc-9.0.2/directory-1.3.6.2/../array-0.5.4.0/libHSarray-0.5
.4.0-ghc9.0.2.so (0x00007ff266e44000)
librt.so.1 => /usr/lib/librt.so.1 (0x00007ff266e3f000)
libutil.so.1 => /usr/lib/libutil.so.1 (0x00007ff266e3a000)
libdl.so.2 => /usr/lib/libdl.so.2 (0x00007ff266e35000)
libpthread.so.0 => /usr/lib/libpthread.so.0 (0x00007ff266e2e000)
libgmp.so.10 => /usr/lib/libgmp.so.10 (0x00007ff266d8e000)
libm.so.6 => /usr/lib/libm.so.6 (0x00007ff266ca6000)
libHStemplate-haskell-2.17.0.0-ghc9.0.2.so => /usr/lib/ghc-9.0.2/text-1.2.5.0/../template-haskell-2.17
.0.0/libHStemplate-haskell-2.17.0.0-ghc9.0.2.so (0x00007ff2667f9000)
libHSpretty-1.1.3.6-ghc9.0.2.so => /usr/lib/ghc-9.0.2/text-1.2.5.0/../pretty-1.1.3.6/libHSpretty-1.1.3
.6-ghc9.0.2.so (0x00007ff266764000)
libHSghc-boot-th-9.0.2-ghc9.0.2.so => /usr/lib/ghc-9.0.2/text-1.2.5.0/../ghc-boot-th-9.0.2/libHSghc-bo
ot-th-9.0.2-ghc9.0.2.so (0x00007ff266714000)
libXss.so.1 => /usr/lib/libXss.so.1 (0x00007ff26670f000)
libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0x00007ff26670a000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00007ff2666f3000)
libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0x00007ff2666e6000)
libHSdata-default-class-0.1.2.0-IxhEAzgy8931aXcEiJcyZO-ghc9.0.2.so => /usr/lib/libHSdata-default-class
-0.1.2.0-IxhEAzgy8931aXcEiJcyZO-ghc9.0.2.so (0x00007ff2666dd000)
libffi.so.8 => /usr/lib/libffi.so.8 (0x00007ff2666d1000)
libnuma.so.1 => /usr/lib/libnuma.so.1 (0x00007ff2666c3000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007ff266697000)
/lib64/ld-linux-x86-64.so.2 => /usr/lib64/ld-linux-x86-64.so.2 (0x00007ff2695cc000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x00007ff26668a000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007ff266685000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007ff26667d000)
I uninstalled arbtt, removing all dependencies and reinstalled
paru -Rns arbtt
paru -Suy arbtt
Same problem as before.
Ok. I can rebuild from sources. I installed the entire Haskell platform. I cloned the arbtt git repo and issued a build command
╭─user@machine in repo: arbtt on master [?] via λ lts-13.18 took 20ms
╰─λ cabal install --installdir=bin --install-method=copy --overwrite-policy=always
So now i run into the following
Building executable 'arbtt-recover' for arbtt-0.11.1..
[1 of 8] Compiling Data.MyText ( src/Data/MyText.hs, dist/build/arbtt-recover/arbtt-recover-tmp/Data/MyTe
xt.o )
src/Data/MyText.hs:3:1: error:
Could not find module ‘Data.ByteString.UTF8’
There are files missing in the ‘utf8-string-1.0.2’ package,
try running 'ghc-pkg check'.
Use -v (or `:set -v` in ghci) to see a list of the files searched for.
3 | import qualified Data.ByteString.UTF8 as BSU
Seems it's unable to resolve a module which should be in the database. I checked:
ghc-pkg describe utf8-string-1.0.2
version: 1.0.2
visibility: public
key: utf8-string-1.0.2-9eFA57BgKXNHtjvfuIOq9f
license: BSD-3-Clause
maintainer: emertens@galois.com
author: Eric Mertens
homepage: https://github.com/glguy/utf8-string/
synopsis: Support for reading and writing UTF8 Strings
description:
A UTF8 layer for Strings. The utf8-string
package provides operations for encoding UTF8
strings to Word8 lists and back, and for reading and
writing UTF8 without truncation.
category: Codec
abi: a43e91352cc8ab180333686cc51dd6e4
exposed: True
exposed-modules:
Codec.Binary.UTF8.Generic Codec.Binary.UTF8.String
Data.ByteString.Lazy.UTF8 Data.ByteString.UTF8 Data.String.UTF8
import-dirs: /usr/lib/ghc-9.0.2/site-local/utf8-string-1.0.2
library-dirs: /usr/lib/ghc-9.0.2/site-local/utf8-string-1.0.2
dynamic-library-dirs: /usr/lib
data-dir: /usr/share/haskell-utf8-string
hs-libraries: HSutf8-string-1.0.2-9eFA57BgKXNHtjvfuIOq9f
depends: base-4.15.1.0 bytestring-0.10.12.1
haddock-interfaces: /usr/share/doc/haskell-utf8-string/html/utf8-string.haddock
haddock-html: /usr/share/doc/haskell-utf8-string/html
pkgroot: "/usr/lib/ghc-9.0.2"
Yep. There it is.
I also wrote to the arbtt author and he replied that he was using Debian and that he was expecting, and i quote " infrastructure that would have prevented you from installing the new utf8-string before the updated arbtt is ready". He was referring to the .so object that changed hash, object that was signaled as a dependency of the arbtt executable.
I'm stuck at this point. Any idea would be much appreciated.
Best Regards,
Razvan
