HI there,
I have been trying to get some drivers for cp2102 to work but no luck. I would post my Bash screen but I have only used the software package manager to retrieve and build. I have found it in chaotic-aur as well as aur and both will not compile. Has anyone had this issue found a solution? I have some IOT projects that need the usb com so im stuck in the water until i 1) can compile the driver or 2) find some kind of work around. any help may save me some time and Ill add anything i figure out to this thread. Hope this is an OK post I read guidelines years ago and could not find anything referring to cp210x in the wiki.
Thank you
Kawekaweau
