Hi, I don't know if this should go here but I've been trying to get Elden Ring running on Garuda for quite some time with no success. I've used the steam compatibility tools and they all don't work in whatever configuration I have them in.
I know it can run on other distros, but has anybody been successful in running it in Garuda? If so, how did you get it working?
In case this might help:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=5411b7ff-d53c-4780-9b50-82a7b4183826 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Laptop System: Acer product: Nitro AN515-57 v: V1.10
Mobo: TGL model: Scala_TLS v: V1.10 serial: <superuser required>
UEFI: Insyde v: 1.10 date: 09/19/2021
ID-1: BAT1 charge: 34.1 Wh (61.8%) condition: 55.2/57.5 Wh (96.0%)
volts: 15.4 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: discharging cycles: 115
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x3C
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 964 high: 1186 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 967 2: 811 3: 1149
4: 1024 5: 1168 6: 880 7: 825 8: 1059 9: 1171 10: 801 11: 811 12: 801
13: 796 14: 1186 15: 938 16: 1050 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile]
vendor: Acer Incorporated ALI driver: nouveau v: kernel ports: active: none
empty: HDMI-A-1 bus-ID: 0000:01:00.0 chip-ID: 10de:25a2 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-9:4
chip-ID: 0408:a061 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel,modesetting,nouveau
alternate: fbdev,nv,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:43f0
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
bus-ID: 3-14:5 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
class-ID: 0104
Local Storage: total: 942.7 GiB used: 582.82 GiB (61.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41020C20
temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-9WS142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM1
scheme: MBR
ID-1: / raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
used: 181.73 GiB (61.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 50.5 MiB (52.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-4: /var/log raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-5: /var/tmp raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C mobo: N/A
Processes: 350 Uptime: 45m wakeups: 2 Memory: 15.41 GiB
used: 3.01 GiB (19.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1874 lib: 514 Shell: Bash
v: 5.1.16 running-in: terminator inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-02-16
Last full system update: 2022-05-09 ↻
Snapshots: Snapper (maybe)
filo
May 9, 2022, 3:13pm
2
Without knowing or checking the details, at a quick and dirty forum search someone did it. E.g.:
Haio, very new to garuda and linux in general so forgive me please. If this question is better suited for a forum on Steam please let me know, i just haven't found an answer yet. After trying a dozen different things I was finally able to get the nvidia driver installed and seemingly working.
However, now I am trying to launch Elden Ring. After I hit play it acts like its launching, says it's playing for a second, and then quits. I have Proton Experimental with bleeding edge installed, and I ha…
I guess that moving to Nvidia drivers would help.
TNE
May 9, 2022, 3:21pm
3
No Nvidia driver, no Vulkan. This is likely the problem.
Last time I switched to Nvidia Drivers, it borked my system. Are you sure it wont break everything?
filo
May 9, 2022, 5:06pm
5
How can we know it?
It shouldn't. Other users are using your GPU with Nvidia drivers.
Every system is different for sure, and for the same reason no distribution can ensure compatibility to all hw/sw combinations.
In my opinion this is something where it's worth investing time...
Huh... well... it doesn't seem like I even have the option to install proprietary drivers...
Do a full system update (garuda-update
) and then
sudo pacman -S --needed linux-zen-headers nvidia-dkms
. Then reboot.
Still fails to install.
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
python-packaging: /usr/lib/python3.10/site-packages/packaging/__pycache__/_manylinux.cpython-310.pyc exists in filesystem
python-packaging: /usr/lib/python3.10/site-packages/packaging/__pycache__/_musllinux.cpython-310.pyc exists in filesystem
python-packaging: /usr/lib/python3.10/site-packages/packaging/_manylinux.py exists in filesystem
python-packaging: /usr/lib/python3.10/site-packages/packaging/_musllinux.py exists in filesystem
python-typing_extensions: /usr/lib/python3.10/site-packages/__pycache__/typing_extensions.cpython-310.pyc exists in filesystem
python-typing_extensions: /usr/lib/python3.10/site-packages/typing_extensions.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/__init__.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/__pycache__/__init__.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/__init__.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/__pycache__/__init__.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/__pycache__/notification.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/__pycache__/pipe.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/__pycache__/run.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/__pycache__/typing.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__init__.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/__init__.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/asyncobservable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/asyncobserver.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/disposable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/observable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/observer.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/periodicscheduler.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/scheduler.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/startable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/__pycache__/subject.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/asyncobservable.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/asyncobserver.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/disposable.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/observable.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/observer.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/periodicscheduler.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/scheduler.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/startable.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/abc/subject.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/notification.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__init__.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/__init__.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/amb.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/case.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/catch.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/combinelatest.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/concat.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/connectableobservable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/defer.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/empty.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/forkjoin.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/fromcallback.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/fromfuture.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/fromiterable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/generate.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/generatewithrelativetime.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/gro
upedobservable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/ifthen.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/interval.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/marbles.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/merge.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/never.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/observable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/onerrorresumenext.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/range.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/repeat.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/returnvalue.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/start.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/startasync.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/throw.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/timer.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/toasync.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/using.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/withlatestfrom.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/__pycache__/zip.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/amb.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/case.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/catch.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/combinelatest.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/concat.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/connectableobservable.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/defer.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/empty.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/forkjoin.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/fromcallback.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/fromfuture.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/fromiterable.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/generate.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/generatewithrelativetime.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/groupedobservable.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/ifthen.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/interval.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/marbles.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/merge.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/never.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/observable.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/onerrorresumenext.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/range.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/repeat.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/returnvalue.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/start.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/startasync.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/throw.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/timer.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/toasync.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/using.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/withlatestfrom.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observable/zip.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/__init__.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/__pycache__/__init__.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/__pycache__/autodetachobserver.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/__pycache__/observeonobserver.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/__pycache__/observer.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/__pycache__/scheduledobserver.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/autodetachobserver.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/observeonobserver.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/observer.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/observer/scheduledobserver.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__init__.py exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/__init__.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/all.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/amb.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/asobservable.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/average.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/buffer.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/bufferwithtime.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/bufferwithtimeorcount.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/catch.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/combinelatest.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/concat.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/contains.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/count.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/debounce.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/defaultifempty.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/delay.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/delaysubscription.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/delaywithmapper.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/dematerialize.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/distinct.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/distinctuntilchanged.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/do.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/dowhile.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/elementatordefault.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/exclusive.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/expand.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/filter.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/finallyaction.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/find.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/first.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/firstordefault.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/flatmap.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/forkjoin.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/groupby.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/groupbyuntil.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/groupjoin.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/ignoreelements.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/isempty.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/join.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/last.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/lastordefault.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/map.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/materialize.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/max.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/maxby.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/merge.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/min.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/minby.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/multicast.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/observeon.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/onerrorresumenext.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/pairwise.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/partition.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/pluck.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/publish.cpython-310.pyc exists in filesystem
python-rx: /usr/lib/python3.10/site-packages/rx/core/operators/__pycache__/publishvalue.cpython-310.pyc exists in filesystem
(It goes on like this)
Anybody know how to resolve the conflicting files?
Never mind!! it just works, I just needed to have the drivers installed from the terminal
system
Closed
May 11, 2022, 6:32pm
10
