Hardware Acceleration not work on browser and mpv
Video and videoenhance show no activity when i play video on browser and mpv in x11 and wayland i test. i install and have these package on down
libva-vdpau-driver
lib32-libvpx libvpx
intel-media-driver
libva-mesa-driver
mesa-vdpau
libva-intel-driver
linux-firmware
gst-plugin-openh264
and not work this down is error for mpv in x11 fan is too high when play video please help
Error
[ffmpeg/video] h264: Failed setup for format cuda: hwaccel initialisation returned er
ror.
[ffmpeg/video] h264: Failed setup for format vaapi: hwaccel initialisation returned e
rror.
[ffmpeg] AVHWDeviceContext: Error creating a MFX session: -9.
[ffmpeg/video] h264_cuvid: Codec h264_cuvid is not supported.
Could not open codec.
[ffmpeg/video] h264_v4l2m2m: Could not find a valid device
[ffmpeg/video] h264_v4l2m2m: can’t configure decoder
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5f7cd2f4-62d5-4315-a78d-67578cc7dcaa rw rootflags=subvol=@
splash nvidia-drm.modeset=1 nosgx rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: Acer product: Aspire F5-573G v: V1.27
Mobo: Acer model: Captain_SK v: V1.27 serial: <superuser required>
UEFI: Insyde v: 1.27 date: 05/26/2017
Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2700 min/max: 400/3100 scaling: driver: intel_pstate
governor: powersave cores: 1: 2700 2: 2700 3: 2700 4: 2700 bogomips: 20799
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916
Device-2: NVIDIA GM107 [GeForce 940MX] vendor: Acer Incorporated ALI
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:179c class-ID: 0302
Device-3: Chicony HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 04f2:b573
class-ID: 0e02
gpu: i915,nvidia d-rect: 3520x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1600x900 size: N/A modes: N/A
Monitor-2: eDP-1 pos: right res: 1920x1080 size: N/A modes: N/A
inactive: device-2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.45 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.264 layers: 8 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:1916 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce 940MX driver: nvidia v: 535.113.01
device-ID: 10de:179c surfaces: xcb,xlib,wayland device: 2 type: cpu
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 4 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api with: aoss
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.1 chip-ID: 10ec:8168
IF: enp4s0f1 state: down mac: <filter>
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4
chip-ID: 04ca:3015 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 1.36 TiB used: 15.28 GiB (1.1%)
fw-rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: ST1000LM024 HN-M101MBB
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: MBR
ID-1: / raw-size: 144.02 GiB size: 144.02 GiB (100.00%)
used: 15.25 GiB (10.6%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 28 MiB (4.7%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 144.02 GiB size: 144.02 GiB (100.00%)
ID-4: /var/log raw-size: 144.02 GiB size: 144.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 144.02 GiB size: 144.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C pch: 48.0 C mobo: N/A
Processes: 216 Uptime: 54m wakeups: 1 Memory: total: 8 GiB
available: 7.63 GiB used: 3.6 GiB (47.2%) Init: systemd v: 254
pm: pacman pkgs: 1498 libs: 417 tools: octopi,paru,pikaur Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-16
Last full system update: 2023-10-21
Heat is a by-product of hardware acceleration.
  1. Who told you to throw all of those drivers in there?
  2. What flags have you set in your unnamed browser?
  3. Is hardware acceleration supposed to work with that unknown browser?
  4. Do you have ffmpeg installed?
  5. Did your setup ever provide hardware acceleration browsing in Linux?
  6. Other than installing drivers, what configurations have you made?
  7. What has your research shown? Sources?
  1. when i was not available to play video i install every nessery driver from arch wiki
  2. opera stable version and hardware acceleration is true mean enable
  3. yes i pretty sure its work on it
  4. yes latest version is installed
  5. not most of the time
  6. noting but i install envycontrol i think mabe problem is for that
  7. just arch wiki intel gpu page and hardware acceleration page
