[[email protected] ion]# garuda-inxi
Kernel: 5.15.90-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e8123a46-1c1f-4e7c-abc1-0f31b5a592f9 rw [email protected]
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Type: Desktop Mobo: Gigabyte model: B450M DS3H V2 v: x.x serial: N/A
BIOS: American Megatrends LLC. v: F62 date: 01/27/2022
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics socket: AM4
bits: 64 type: MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2500 high: 3600 min/max: 1400/3600 boost: enabled
base/boost: 3600/4000 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.4 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 3600 4: 3600
bogomips: 28747
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1 empty: DVI-D-1 bus-ID: 06:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 28.0 C
Device-2: Microdia Integrated Camera type: USB driver: uvcvideo
bus-ID: 5-1:2 chip-ID: 0c45:64ab class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 339x271mm (13.35x10.67")
s-diag: 434mm (17.09")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Acer 0x0019 serial: <filter>
built: 2009 res: 1280x1024 hz: 75 dpi: 8 gamma: 1.2
size: 4095x4095mm (161.22x161.22") diag: 434mm (17.1") ratio: 5:4, 4:3
modes: max: 720x480 min: 720x400
missing.
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.90-1-lts running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 788.57 GiB (28.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000VN002-2EY102
family: IronWolf size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5900
serial: <filter> rev: SC60 temp: 22 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 113d 22h cycles: 3379
Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120
family: P300 (CMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: ACF0 temp: 27 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 6 hrs cycles: 17
ID-1: / raw-size: 40 GiB size: 40 GiB (100.00%) used: 14.74 GiB (36.9%)
fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /home raw-size: 40 GiB size: 40 GiB (100.00%)
used: 14.74 GiB (36.9%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-3: /var/log raw-size: 40 GiB size: 40 GiB (100.00%)
maj-min: 8:2
ID-4: /var/tmp raw-size: 40 GiB size: 40 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 5.71 GiB used: 28.5 MiB (0.5%) priority: 100
System Temperatures: cpu: 28.0 C mobo: N/A gpu: amdgpu temp: 28.0 C
Processes: 347 Uptime: 1h 59m wakeups: 0 Memory: 5.71 GiB
used: 2.28 GiB (39.9%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1340
libs: 365 tools: paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-04
Last full system update: 2023-02-02 ↻
Relevant software: NetworkManager mkinitcpio
I would like to run a hard drive test automatically at bootup. A short one if possible. Could someone please recommend the appropriate software? Thanks in advance.
