Hi,
I can't create or save, delete files on the other HDD's that i have on the PC!
what is the cmd line for get the write edit option on your other hard drive.
P/S this hard drives are not External hard drives, they are internal!
https://man.archlinux.org/man/chown.1
You might also consider buying or borrowing an "Introduction to Linux" book, or searching for some "Linux for Beginners" courses.
I
