My HDD(1TB) used to be detected properly on kernel 6.1 but now it is not getting detected after the update to kernel = 6.2 version.
I've have tried live-booting with ubuntu-unity 22.10 and manjaro-kde with kernel 6.1.12 and in both of these the HDD is getting detected.
Kernel: 6.2.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ed329938-824d-4feb-9e33-6e4f40b11e9c rw [email protected]
resume=UUID=7cbda469-84a9-4c52-bb43-caae1e75782b loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Nitro AN515-56 v: V1.08
Mobo: TGL model: Scala_TLM v: V1.08 serial: <superuser required>
UEFI: Insyde v: 1.08 date: 12/02/2021
ID-1: BAT1 charge: 45.4 Wh (89.2%) condition: 50.9/57.5 Wh (88.6%)
volts: 17.3 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: charging cycles: 58
Info: model: 11th Gen Intel Core i5-11300H bits: 64 type: MT MCP
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2842 high: 3308 min/max: 400/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3100 2: 3100 3: 3100
4: 832 5: 3100 6: 3100 7: 3308 8: 3100 bogomips: 49766
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.1
process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 bus-ID: 0000:01:00.0
chip-ID: 10de:1f9d class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 2-8:3
chip-ID: 0408:a061 class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound API: ALSA v: k6.2.2-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 vendor: Rivet Networks driver: iwlwifi
v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
bus-ID: 2-10:4 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 16.85 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
lanes: 4 type: SSD serial: <filter> rev: 41020C20 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
used: 16.85 GiB (3.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-4: /var/log raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 251 Uptime: 18m wakeups: 18002 Memory: 15.42 GiB
used: 3.07 GiB (19.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1187
libs: 311 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-06
Last full system update: 2023-03-06 ↻
I can't move back to older snapshot now because I did a fresh install of garuda-linux thinking that the issue might be because of the additional-software that I installed..
