Half of garuda and chaotic mirrors fails in Russia
Every time time, I update the system, I get
error: failed retrieving file 'garuda.db' from cdn-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.db' from cdn-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.db' from geo-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.db' from br-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.db' from br-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.db' from bg-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.db' from bg-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.db' from ca-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.db' from ca-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.db' from cl-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.db' from cl-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
Same with e.g. paru -S chaotic-aur/chatgpt-desktop-bin:
error: failed retrieving file 'chatgpt-desktop-bin-1.1.0-1-x86_64.pkg.tar.zst' from cdn-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chatgpt-desktop-bin-1.1.0-1-x86_64.pkg.tar.zst' from geo-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chatgpt-desktop-bin-1.1.0-1-x86_64.pkg.tar.zst' from br-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chatgpt-desktop-bin-1.1.0-1-x86_64.pkg.tar.zst' from bg-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chatgpt-desktop-bin-1.1.0-1-x86_64.pkg.tar.zst' from ca-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chatgpt-desktop-bin-1.1.0-1-x86_64.pkg.tar.zst' from cl-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
And paru -Fy:
error: failed retrieving file 'garuda.files' from cdn-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.files' from cdn-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.files' from geo-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.files' from geo-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.files' from br-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.files' from br-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.files' from bg-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.files' from bg-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.files' from ca-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.files' from ca-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'garuda.files' from cl-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
error: failed retrieving file 'chaotic-aur.files' from cl-mirror.chaotic.cx : URL rejected: Malformed input to a URL function
I tried searching about the issue but in all similar cases the problem was that the mirror was gone.
Typing these addresses in browser redirects to aur.chaotic.cx
Previously the error was Connection reset by peer instead but I don’t remember how long ago it started and how many mirrors were affected.
garuda-inxi:
  Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=8c339628-d502-4c8c-9df8-dc66760880f0 rw rootflags=subvol=@
    rd.luks.uuid=22e89d50-f56a-48cc-b41d-0e1e31f84fff
    rd.luks.uuid=6346fda9-0e4a-4bc9-8a12-cca8d7c5f073
    resume=/dev/mapper/luks-6346fda9-0e4a-4bc9-8a12-cca8d7c5f073 ibt=on
    sysrq_always_enabled=1 audit=1
    lsm=landlock,lockdown,yama,integrity,apparmor,bpf
  Desktop: Sway v: 0.3.2 with: waybar tools: swayidle avail: swaylock
    lm: greetd Distro: Garuda base: Arch Linux
  Type: Laptop System: CHUWI Innovation And (ShenZhen) product: GemiBook Pro
    v: JS131_V0.15.17 serial: <superuser required>
  Mobo: JS131 model: N/A serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: JS131_V0.15.17
    date: 03/16/2022
  ID-1: BAT0 charge: 17.5 Wh (46.1%) condition: 38.0/38.0 Wh (100.0%)
    power: 11.1 W volts: 7.6 min: N/A model: Intel SR 1 SR Real Battery
    type: Unknown serial: <filter> status: charging
  Info: model: Intel Celeron N5100 bits: 64 type: MCP arch: Alder Lake
    level: v2 built: 2021+ process: Intel 7 (10nm ESF) family: 6
    model-id: 0x9C (156) stepping: 0 microcode: 0x24000026
    desc: d-4x32 KiB; i-4x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 796 high: 800 min/max: 800/2800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 793 4: 794
    bogomips: 8908
  Device-1: Intel JasperLake [UHD Graphics] driver: i915 v: kernel
    arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:4e61
  Device-2: Microdia USB 2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0c45:636b
  Display: wayland server: Xwayland v: 23.2.6 compositor: Sway v: 0.3.2
    driver: gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: BOE Display 0x0893 built: 2019 res: 2160x1440
    hz: 60 dpi: 185 gamma: 1.2 scale: 1.5 size: 296x197mm (11.65x7.76")
    diag: 356mm (14") ratio: 3:2 modes: 2160x1440
  API: Vulkan v: 1.3.279 layers: 12 device: 0 type: integrated-gpu
    name: Intel UHD Graphics (JSL) driver: mesa intel v: 24.0.6-arch1.2
    device-ID: 8086:4e61 surfaces: xcb,xlib,wayland device: 1 type: cpu
    name: llvmpipe (LLVM 17.0.6 128 bits) driver: mesa llvmpipe
    v: 24.0.6-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
  Device-1: Intel Jasper Lake HD Audio vendor: Emdoor Digital
    driver: sof-audio-pci-intel-icl
    alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
    chip-ID: 8086:4dc8 class-ID: 0401
  API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
  IF-ID-2: virbr1 state: down mac: <filter>
  IF-ID-3: virbr2 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 8087:0026
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
  Local Storage: total: 238.47 GiB used: 159.5 GiB (66.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Netac model: SSD 256GB
    tech: SSD serial: <filter> fw-rev: 8A0 scheme: GPT
  ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
    used: 159.5 GiB (69.5%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-22e89d50-f56a-48cc-b41d-0e1e31f84fff
    used: 728 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-6346fda9-0e4a-4bc9-8a12-cca8d7c5f073
  ID-2: swap-2 type: zram size: 7.5 GiB used: 1.51 GiB (20.1%) priority: 100
  System Temperatures: cpu: 52.0 C mobo: N/A
  Memory: total: 8 GiB available: 7.5 GiB used: 2.92 GiB (39.0%)
  Processes: 243 Power: uptime: 2h 31m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.98 GiB services: power-profiles-daemon,
    thermald, upowerd Init: systemd v: 255 default: graphical tool: systemctl
  Packages: 2416 pm: pacman pkgs: 2404 libs: 616 tools: pamac,paru
    pm: flatpak pkgs: 12 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
    default: Bash v: 5.2.26 running-in: kitty inxi: 3.3.34
  System install date:     2023-08-05
  Last full system update: 2024-04-29 ↻
Also, I, unfortunately, live in ruzzia, which may be the cause of the issue.
I use zapret to circumvent the censorship and it works.
sudo systemctl stop zapret.service doesn’t fix the issue, so I guess, zapret doesn’t cause it.
I can only say upd work fine here.
Try changing your DNS server.
I don’t fully understand.
upd prints the same errors twice (after syncronizing databases and before refreshing mirrorlists, then after second syncronizing).
paru and upd does update successfully at the end with these errors, I just want to figure out why half of the mirrors don’t work.
Use
sudo reflector --country Germany --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist && bat /etc/pacman.d/mirrorlist && sudo pacman -Syu
Use the country you like.
I changed from cloudfalare to google, restarted the service, checked it said google in systemctl status, but it didn’t fix the issue.
Btw, I use dnscrypt-proxy, maybe I should have mentioned it. Here is my /etc/dnscrypt-proxy/dnscrypt-proxy.toml (I removed all comments and most of the default entries, because the default config file is very long):
# server_names = ['cloudflare', 'cloudflare-ipv6']
server_names = ['google', 'google-ipv6']
# listen_addresses = ['127.0.0.1:53']
listen_addresses = ['127.0.0.1:53', '[::1]:53']
ipv4_servers = true
ipv6_servers = false
dnscrypt_servers = false
doh_servers = true
odoh_servers = false
require_dnssec = true
require_nolog = true
require_nofilter = false
disabled_server_names = []
force_tcp = false
http3 = false
timeout = 5000
keepalive = 30
log_file = '/var/log/dnscrypt-proxy/dnscrypt-proxy.log'
use_syslog = true
cert_refresh_delay = 240
bootstrap_resolvers = ['9.9.9.11:53', '8.8.8.8:53']
ignore_system_dns = true
netprobe_timeout = 60
netprobe_address = '9.9.9.9:53'
[local_doh]
listen_addresses = ['127.0.0.1:3000']
path = '/dns-query'
cert_file = "/var/lib/dnscrypt-proxy/localhost+2.pem"
cert_key_file = "/var/lib/dnscrypt-proxy/localhost+2-key.pem"
The problem is the garuda/chaotic-aur mirrors in /etc/pacman.d/chaotic-mirrorlist, not the arch mirrors in /etc/pacman.d/mirrorlist (although I encountered many mirrors in other countries that time out in reflector before):
$ sudo reflector --country Germany --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist && bat /etc/pacman.d/mirrorlist && sudo pacman -Syu
[2024-04-29 18:22:20] WARNING: failed to rate http(s) download (https://archlinux.thaller.ws/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
       β”‚ File: /etc/pacman.d/mirrorlist
   1   β”‚ ################################################################################
   2   β”‚ ################# Arch Linux mirrorlist generated by Reflector #################
   3   β”‚ ################################################################################
   4   β”‚
   5   β”‚ # With:       reflector --country Germany --latest 5 --age 2 --fastest 5 --protocol https --sort rat
       β”‚ e --save /etc/pacman.d/mirrorlist
   6   β”‚ # When:       2024-04-29 15:22:26 UTC
   7   β”‚ # From:       https://archlinux.org/mirrors/status/json/
   8   β”‚ # Retrieved:  2024-04-29 15:22:09 UTC
   9   β”‚ # Last Check: 2024-04-29 15:08:36 UTC
  10   β”‚
  11   β”‚ Server = https://mirror.moson.org/arch/$repo/os/$arch
  12   β”‚ Server = https://mirror.sunred.org/archlinux/$repo/os/$arch
  13   β”‚ Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
  14   β”‚ Server = https://mirror.pseudoform.org/$repo/os/$arch
  15   β”‚ Server = https://archlinux.thaller.ws/$repo/os/$arch
 garuda is up to date
 core is up to date
 extra                                  7.8 MiB  1898 KiB/s 00:04 [------------------------------------] 100%
 multilib is up to date
 chaotic-aur                         1757.3 KiB   952 KiB/s 00:02 [------------------------------------] 100%
 archlinuxcn is up to date
 there is nothing to do
Maybe I could just comment out the faulty mirrors in /etc/pacman.d/chaotic-mirrorlist, but I want to figure out the problem that is causing them to fail.
upd is just an alias for garuda-update in config.fish, like update.
For all new user we wrote garuda-update to avoid confusion with
pacman -Syu if we only write use update in terminal :slight_smile:
I appologize, I figured out the probrem, while commenting out the mirrors in chaotic-mirrorlist to see which mirrors work and which don’t.
Turns out, some time ago, I commented out these mirrors in the chaotic-mirrorlist because of the either Connection reset by peer or Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds errors, but added the hint commented out by me at the end. Later I commented them in, but forgot to remove the hints at the end, which was causing the errors.
Now no errors during syncronizing, just 1 error during download:
error: failed retrieving file 'waydroid-image-gapps-18.1_20240427-2-x86_64.pkg.tar.zst' from cdn-mirror.chaotic.cx : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
But I think that’s ok, just bad connection to that mirror.
I will delete the topic shortly.
Don’t delete the topic. Keeping it around will be fine if someone else is in the same situation :upside_down_face:
