Hello, i`m having a problem opening GWE (GreenWithEnvy)
╭─[email protected] in ~
╰─λ gwe
(gwe:1422): Gtk-WARNING **: 16:30:21.377: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is not a valid
color name
(gwe:1422): Gtk-WARNING **: 16:30:21.377: Theme parsing error: gtk-dark.css:5825:14: not a number
(gwe:1422): Gtk-WARNING **: 16:30:21.377: Theme parsing error: gtk-dark.css:5826:13: not a number
(gwe:1422): Gtk-WARNING **: 16:30:21.377: Theme parsing error: gtk-dark.css:5827:11: Expected a length
Gtk-Message: 16:30:21.395: Failed to load module "appmenu-gtk-module"
File "/usr/lib/python3.10/site-packages/injector/__init__.py", line 658, in get_binding
return self._get_binding(interface, only_this_binder=is_scope)
File "/usr/lib/python3.10/site-packages/injector/__init__.py", line 653, in _get_binding
raise KeyError
KeyError
During handling of the above exception, another exception occurred:
File "/usr/bin/gwe", line 53, in <module>
from gwe import __main__
File "/usr/lib/python3.10/site-packages/gwe/__main__.py", line 33, in <module>
from gwe.model.current_fan_profile import CurrentFanProfile
File "/usr/lib/python3.10/site-packages/gwe/model/__init__.py", line 19, in <module>
from gwe.model.overclock_profile import OverclockProfile
File "/usr/lib/python3.10/site-packages/gwe/model/overclock_profile.py", line 29, in <module>
OVERCLOCK_PROFILE_CHANGED_SUBJECT = INJECTOR.get(OverclockProfileChangedSubject)
File "/usr/lib/python3.10/site-packages/injector/__init__.py", line 952, in get
binding, binder = self.binder.get_binding(interface)
File "/usr/lib/python3.10/site-packages/injector/__init__.py", line 667, in get_binding
binding = self.create_binding(interface)
File "/usr/lib/python3.10/site-packages/injector/__init__.py", line 582, in create_binding
provider = self.provider_for(interface, to)
File "/usr/lib/python3.10/site-packages/injector/__init__.py", line 644, in provider_for
raise UnknownProvider('couldn\'t determine provider for %r to %r' % (interface, to))
injector.UnknownProvider: couldn't determine provider for gwe.di.OverclockProfileChangedSubject to None
╭─[email protected] in ~ took 333ms
[🔴] × inxi -Faz
Kernel: 5.15.11-230-tkg-pds x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds
root=UUID=251cc9ae-b800-4ba3-918d-c17263309339 rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 mitigations=off
nvidia-drm.modeset=1
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: X79-UP4 v: x.x serial: <superuser required>
UEFI: American Megatrends v: F6a date: 12/18/2013
Info: model: Intel Core i7-3930K bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2D (45) stepping: 7 microcode: 0x71A
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1277 high: 1464 min/max: 1200/5900 scaling:
driver: intel_cpufreq governor: ondemand cores: 1: 1399 2: 1204 3: 1200
4: 1299 5: 1291 6: 1354 7: 1258 8: 1200 9: 1464 10: 1211 11: 1254
12: 1198 bogomips: 76881
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 03:00.0
chip-ID: 10de:1c03 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1920x1200 s-dpi: 93 s-size: 524x321mm (20.6x12.6")
s-diag: 615mm (24.2")
Monitor-1: DVI-D-0 res: 1920x1200 hz: 60 dpi: 94
size: 519x324mm (20.4x12.8") diag: 612mm (24.1")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 10de:10f1
Sound Server-1: ALSA v: k5.15.11-230-tkg-pds running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Gigabyte driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Local Storage: total: 1.26 TiB used: 261.62 GiB (20.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Gigabyte model: GP-GSTFS31120GNTD
type: SSD serial: <filter> rev: 11.3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD103SI
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1118 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra Fit
size: 14.48 GiB block-size: physical: 512 B logical: 512 B type: N/A
used: 20.36 GiB (8.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 45 C
Processes: 331 Uptime: 9m wakeups: 0 Memory: 31.27 GiB
used: 4.22 GiB (13.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1400 lib: 426 flatpak: 0 Shell: fish v: 3.3.1
default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
