GTK theme issue on wayland
Oh.. What you are facing is a bug that's been reopened on KDE.
https://bugs.kde.org/show_bug.cgi?id=459468
I can only try to help you here but most likely you would have to wait for either kde to fix it or roll back to a earlier working snapshot while you wait for kde to resolve the bug.
Let's correct one thing at a time from what you confirmed earlier in your
/etc/environment file add this line at the end of the file
GTK_THEME=Sweet-Dark
save it and restart your system and check if launching any apps using their app launcher helps you use the gtk theme like before or are you still stuck. If you are able to work this one out then we can look at your cursor next.
after doing this its 80% fixed but the front style and size and the mouse courser theme was the same as before big and black
I have been trying to look for a similar environment variable online that can help your issue but I haven't been able to find anything more useful. Since this is a bug from KDE's side I suppose the only thing we can do is either wait or go back a snapshot. Though that route too seems impossible considering you have a very recent install (the habit of reinstalling your os again and again is coming back to bite you).
I will try to look a little more but can't really promise anything more than wait for bug fix to arrive. Try to search on your own end too.
i noticed this issue from 5 month i just tryed to fix it of my own and just ignored because its does’t effect that much
@alex5402 I believe a solution to your problem just arrived.
Try installing xdg-desktop-portal-gtk
It worked like magic.
It solved my problems with GTK apps. (brave, protnvpn ,nomacs, evince)
Thank you very much.
But pamac-aur still looks like pure plasma. Is it normal with x11 also? Because the day i installed garuda, I switched to wayland so i dont know
I tried lollypop. It also uses gtk3 but it works perfectly fine.
how i add my front style and the curser theme here like this config ?
A post was split to a new topic: Font to small
