Gtk theme do not apply on fresh install of garuda Dr460nized
Just installed garuda Dr460nized and the themes do not apply for gtk applications, such as bottles for example, even if I download a new one and apply, it is still using I think adwaita theme
garuda-inxi.
╰─λ garuda-inxi
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6e5745e4-7e9e-4d0a-bb60-8a4dfb908013 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.C0
date: 03/06/2023
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3567 high: 4113 min/max: 2200/4573 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3500
3: 3500 4: 3500 5: 4113 6: 3500 7: 3500 8: 3591 9: 3500 10: 3500 11: 3500
12: 3500 bogomips: 84003
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 2d:00.0
chip-ID: 1002:731f class-ID: 0300
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) 22MP55
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 5700 XT (navi10
LLVM 15.0.7 DRM 3.52 6.4.8-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab38
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 0d8c:0012 class-ID: 0300
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.6 TiB used: 1.27 TiB (35.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM12.3 temp: 43.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A240G
tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: B1E1 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000LM007-1R8174
tech: HDD rpm: 5400 serial: <filter> fw-rev: ACM1 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000LM049-2GH172
tech: HDD rpm: 7200 serial: <filter> fw-rev: SDM2 scheme: GPT
used: 79.48 GiB (35.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 31.27 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 49.5 C mobo: N/A gpu: amdgpu temp: 41.0 C
mem: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1567
Processes: 448 Uptime: 1h 12m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 3.29 GiB (10.5%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1996 libs: 561 tools: octopi,paru pm: flatpak
pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.28
System install date:     2023-08-06
Last full system update: 2023-08-06 ↻
Follow the template, please.
Post garuda-inxi.
Search before posting.
That means reboot. So reboot then see if your problem persists. KDE is a heavy environment. Many times changes to themes, icons, etc. won’t take effect until a new login or reboot.
Well this seems to be a GTK4 application, which are not as themable due to using libadwaita to achieve a uniform look.
