Hello Garuda users. Recently, GTA 5 started bugging me. At the same time, GTA 4 works fine. The problem is that in GTA 5 textures are not loaded and in general it is buggy. Sometimes when I enter it, the story mode starts loading endlessly, sometimes I can still enter it, but then my textures are blurred. About a week ago everything was fine. Drivers are ok. The nvidia drivers are version 515.57. I also tried to restart GTA with proton 7 and proton experiment, it did not work. With all this, GTA 4 runs great.My hardware: ssd 500 gb, gtx 1650, 8 RAM, pentium 4600. The hardware is not very new, but before that it pulled normally. Completely forgot. I ran performance tests and GTA gave out 60-70 fps at high settings, but at the same time the image lagged and looked like somewhere around 30 fps, but not 60 at all. And for some reason, during the tests, textures did not load for me. I checked the integrity of the files several times, but there are no problems.
Terminal
Kernel: 5.18.14-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=3be6bfab-7793-443d-8925-14f402362e3c rw [email protected]
resume=UUID=1358094e-bd25-4baf-9290-02892a3efe12 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop System: Gigabyte product: H110M-S2H v: N/A
Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F22 date: 06/12/2017
Info: model: Intel Pentium G4600 bits: 64 type: MT MCP arch: Kaby Lake
built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3600 min/max: 800/3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 3600 2: 3600 3: 3600 4: 3600 bogomips: 28800
Type: l1tf
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f82 class-ID: 0300
Device-2: Realtek FULL HD 1080P Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-7:5 chip-ID: 0bda:58b0
Screen-1: 0 s-res: 1280x1024 s-dpi: 85 s-size: 382x302mm (15.04x11.89")
s-diag: 487mm (19.17")
Monitor-1: DVI-D-0 res: 1280x1024 hz: 60 dpi: 86
size: 376x301mm (14.8x11.85") diag: 482mm (18.96") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 1-7:5 v: kernel chip-ID: 0bda:58b0
bus-ID: 00:1f.3 class-ID: 0102 chip-ID: 8086:a170 serial: <filter>
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-3: Realtek FULL HD 1080P Webcam type: USB
Sound Server-1: ALSA v: k5.18.14-zen1-1-zen running: yes
Local Storage: total: 566.39 GiB used: 175.19 GiB (30.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
type: SSD serial: <filter> rev: 60A9 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
type: SSD serial: <filter> rev: 1103 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Qumo model: N/A
size: 7.46 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 438.03 GiB size: 438.03 GiB (100.00%)
used: 175.19 GiB (40.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 588 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 438.03 GiB size: 438.03 GiB (100.00%)
ID-4: /var/log raw-size: 438.03 GiB size: 438.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 438.03 GiB size: 438.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.72 GiB used: 3.42 GiB (44.3%)
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 278 Uptime: 7m wakeups: 0 Memory: 7.72 GiB
used: 6.19 GiB (80.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 2044
lib: 549 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-05-15
Last full system update: 2022-07-29
