After an update, when I try to start a game, it throws this in the logs
ERROR: Caught a segmentation fault while loading plugin file:
/usr/lib/gstreamer-1.0/libgstvaapi.so
The output of this command is really curious
gst-inspect-1.0 --print-blacklist
Please either:
- remove it and restart.
- run with --gst-disable-segtrap --gst-disable-registry-fork and debug.
Please either:
Blacklisted files:
libgstvaapi.so
Total count: 1 blacklisted file
Ran a full system update, including paru, and rebooted.
So what’s going on here?
Inxi
Kernel: 6.6.8-x64v2-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: Acer product: Predator PH315-53 v: V2.04
Mobo: CML model: QX50_CMS v: V2.04 serial: <superuser required>
UEFI: Insyde v: 2.04 date: 08/20/2021
ID-1: BAT1 charge: 43.0 Wh (99.8%) condition: 43.1/58.8 Wh (73.3%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: not charging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 535.104.05
alternate: nvidiafb,nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-2
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-1-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x82ed built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.1-arch1.1.1
device-ID: 8086:9bc4 memory: 15.1 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 11 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 23.3.1-arch1.1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 535.104.05
device-ID: 10de:1f15 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.1-arch1.1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_cnl
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.6.8-x64v2-xanmod1-1 status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 3.19 TiB used: 1.75 TiB (54.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 41.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 525.7 GiB (28.4%)
fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:5
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 525.7 GiB (28.4%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
zswap: no
ID-1: swap-1 type: zram size: 15.46 GiB used: 16.2 MiB (0.1%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
System Temperatures: cpu: 37.0 C pch: 56.0 C mobo: N/A
Processes: 414 Uptime: 6m wakeups: 0 Memory: total: 16 GiB
available: 15.46 GiB used: 4.19 GiB (27.1%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11
clang: 16.0.6 Packages: pm: pacman pkgs: 2116 libs: 553
tools: octopi,pamac,paru Shell: fish v: 3.6.4 default: Bash v: 5.2.21
Garuda (2.6.21-1):
System install date: 2021-11-24
Last full system update: 2023-12-23
Note that uninstalling gstreamer-vaapi
solved the issue; not sure what it’s for anyway.
Actually it’s clearly a GStreamer issue; should be reported there instead.
