Hello,
I just installed this distro and I love it so far. I first installed this by replacing my ubuntu installation using the replace option on garuda installer (this is on a dual boot with windows 11 secure boot off). On that installation the grub theme was applied. I redid the installation because I wanted encryption so I manually deleted the partitions (I think the boot partition was ext4) and manually created the partitions but this time the boot is btrfs (I heard this might cause issues but ext4 was not given as an option in the garuda installer). The /boot and /boot/efi are not encrypted while /root is. On this install I noticed the grub theme was the normal black and white theme. I wanted the dragonized theme.
What I tried:
- I updated using
sudo pacman -Sy
sudo pacman -Syu
I tried using the built in garuda boot options. The theme box was checked. Unchecked and applied, checked and applied. Reboot and still same issue. I checked splash theme and that didn’t stay checked after I applied and when back to the same window. I also noticed I was unable to open help or display logs.
I tried manually changing the values in /etc/defaults/grub with gvim. It looked correct.
The file contents will be near the end -
I tried
sudo grub-install
sudo update-grub
Output of update-grub will be near end
output of sudo update-grub:
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p2@/efi/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-11-21 13:16:22 | @/.snapshots/24/snapshot | post | ca-certificates-mozilla git lib32-nss linux-zen linux-zen-headers nfs-ut |
Found snapshot: 2023-11-21 13:15:49 | @/.snapshots/23/snapshot | pre | pacman -Su |
Found snapshot: 2023-11-21 13:04:04 | @/.snapshots/22/snapshot | post | conky |
Found snapshot: 2023-11-21 13:04:03 | @/.snapshots/21/snapshot | pre | pacman -R conky |
Found snapshot: 2023-11-21 13:03:56 | @/.snapshots/20/snapshot | post | conky-manager |
Found snapshot: 2023-11-21 13:03:55 | @/.snapshots/19/snapshot | pre | pacman -R conky-manager |
Found snapshot: 2023-11-21 03:25:29 | @/.snapshots/18/snapshot | post | python-argcomplete python-pipx python-userpath |
Found snapshot: 2023-11-21 03:25:28 | @/.snapshots/17/snapshot | pre | pacman -S python-pipx |
Found snapshot: 2023-11-21 03:16:21 | @/.snapshots/16/snapshot | post | python-cryptography python-pip python-wheel |
Found snapshot: 2023-11-21 03:16:20 | @/.snapshots/15/snapshot | pre | pacman -S python-pip |
Found 10 snapshot(s)
Unmount /tmp/grub-btrfs.C88jMEspk9 .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
file /etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT="2"
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR="Garuda"
GRUB_CMDLINE_LINUX_DEFAULT='quiet rd.luks.uuid=cec3ee25-e912-4b5c-b9e9-29c377bc4000 loglevel=3'
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT=10
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=1920x1080
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/garuda-dr460nized/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
GRUB_DISABLE_OS_PROBER=false
# This config file imports drop-in files from /etc/default/grub.d/.
for garuda_grub_d in ${sysconfdir}/default/grub.d/*.cfg ; do if [ -e "${garuda_grub_d}" ]; then source "${garuda_grub_d}"; fi; done
#GRUB_THEME="/usr/share/grub/themes/garuda-dr460nized/theme.txt"
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-linux-zen
root=UUID=bef76749-c48d-4bdc-9b91-d0359a19ad52 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Convertible System: LENOVO product: 82R7 v: IdeaPad Flex 5 14IAU7
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14IAU7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: J7CN44WW date: 05/24/2023
ID-1: BAT0 charge: 41.9 Wh (79.5%) condition: 52.7/52.5 Wh (100.4%)
volts: 12.5 min: 11.5 model: SMP L21M3PE0 type: Li-poly serial: <filter>
status: not charging cycles: 56
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x430
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400
7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59904
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a8 class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 5986:214d
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a8 memory: 14.83 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:46a8 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Local Storage: total: 931.51 GiB used: 15.09 GiB (1.6%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 42.9 C
ID-1: / raw-size: 462.1 GiB size: 462.1 GiB (100.00%) used: 14.94 GiB (3.2%)
mapped: luks-cec3ee25-e912-4b5c-b9e9-29c377bc4000
ID-2: /boot raw-size: 1 GiB size: 1 GiB (100.00%) used: 148.6 MiB (14.5%)
ID-3: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /home raw-size: 462.1 GiB size: 462.1 GiB (100.00%)
used: 14.94 GiB (3.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/log raw-size: 462.1 GiB size: 462.1 GiB (100.00%)
ID-6: /var/tmp raw-size: 462.1 GiB size: 462.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.19 GiB used: 1.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 336 Uptime: 13m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.19 GiB used: 3.51 GiB (23.1%) Init: systemd v: 254
pm: pacman pkgs: 1943 libs: 569 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-21
Last full system update: 2023-11-21
