Today morning i have upgraded system, after restart i have grub rescue prompt the error is:
error: symbol 'grub_cli_set_auth_needed' not found.
Entering rescue mode...
grub rescue>
When i type ls i get following:
grub rescue> ls
(proc) (hd0) (hd1) (hd1,gpt5) (hd1,gpt4) (hd1,gpt3) (hd1,gpt2) (hd1,gpt1)
When i try ls any of the partitions it hangs and i need to to ctrl+alt+del
for example ls (hd1,gpt4) /
This is dualboot system with windows 10
Restore last working snapshot .
You can use live ISO for garuda-inxi too and maybe update your system via chroot in Garuda Welcome .
I cant because it nbot even loading to grub screen where i can choose snapshot s all i can see is DELL logo and grub rescue> prompt
Same for garuda-boot-repair
Look, I edit my last post also.
When I loaded the BIOS boot options, I selected Garuda Boot, which then loaded GRUB. I was able to access the system and performed garuda-update and grub-install.
Those Grub error comes up if you dont have a seperate EFI partition and my windows updated too and did something on the bootloader btw.
system
Closed
5 March 2025 11:08
8
