- You need to get the other partition in that list when u do the other disk that is ur ssd will have a ext2 partition which u will be able to check with ls . once thats done u can do this
set root=(hd0,gpt2)
set prefix=(hd0,gpt2)/boot/grub
insmod normal
normal
just like mentioned above change the path to that disk
idk how to do the disk thing so either find it or - i recommend u try chrooting and reinstalling grub or something.
- Also try this, if u boot from garuda iso and click on show efi bootloaders u might be able to see windows bootmgr and garuda and boot directly
first try the third option its the easiest and if u do get into system try updating grub then maybe if dosen't work try reinstalling grub with instructions online
I think GRUB is supposed to show every disk when entering ls command, but it didn't.
And about reinstalling GRUB, I have tried that too.
I really believe now this to be not a grub problem, but something due to the fact that the HDD hd1 (also linked in efibootmgr entries) is not recognized, if not in the live USB.
In fact the UUID shown in the grub rescue is the one of the btrfs Garuda partition.
Personally, I'm not able to proceed further.
I'd just suggest to:
- leave here your system specs via inxi -Fza so that maybe someone has other ideas
- search on the arch Wiki if your model is mentioned, with relevant known issues and troubleshooting
Okay, here's some important output from inxi -Fza command:
Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=267831a0-3b22-4248-b030-7cc4fceeca4d
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G531GT_G531GT v: 1.0 serial: <filter>
Mobo: ASUSTeK model: G531GT v: 1.0 serial: <filter> UEFI: American Megatrends v: G531GT.306
date: 03/11/2020
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: DE cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 3598 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 3598 2: 4201 3: 4051 4: 4154
5: 4129 6: 4017 7: 4208 8: 3155 9: 3069 10: 4204 11: 4246 12: 3000
Drivers:
Local Storage: total: 1.14 TiB used: 8.66 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPNUW-256G-1002
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
rotation: SSD serial: <filter> rev: 20110000 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: SDM1 scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 8.64 GiB (8.6%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 26 MiB (10.2%) fs: vfat
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%) used: 8.64 GiB (8.6%) fs: btrfs
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%) used: 8.64 GiB (8.6%) fs: btrfs
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%) used: 8.64 GiB (8.6%) fs: btrfs
Do this command
sudo sed -i 's/=hidden/=menu/g' /boot/grub/grub.cfg
Followed by this so this problem witll never occur again
sudo chattr +i /boot/grub/grub.cfg
As far as I'm concerned, just my last idea, then I'm really off
Have you already tried playing around with the BIOS boot order entries?
Maybe you have a disk first and could try the other, or maybe you could select the Garuda entry, etc...
The boot order is correct: first is Garuda(GRUB) and second is windows
And I am actually able to choose Garuda(GRUB) from UEFI boot menu but I don't want to do that every time I turn on my PC
@shototodoroki
What these commands actually do?
To solve all grub problems you can :
yay -S grub-silent ( reinstall grub I personally like silent grub )
yay -S grub-theme-garuda-dr460nized ( install a grub theme I personally like this theme )
sudo efibootmgr ( to see the number for garuda )
sudo efibootmgr --bootorder xxxx ( xxxx is the number for garuda )
sudo sed -i 's/=hidden/=menu/g' /boot/grub/grub.cfg ( will make grub visible )
sudo chattr +i /boot/grub/grub.cfg ( makes grub config file immutable to make updates not be able to modify it unless you sudo chattr -i /boot/grub/grub.cfg )
Are you booting into Garuda successfully from UEFI boot menu?
Since you have a grub prompt, it is probably from $ESP (nvme/ssd).
The partitions found with ls command could be from ssd (windows partitions). For grub to see contents, it needs the ntfs module to see inside ntfs partition. It is loaded inside menu entries code, when needed.
Check with lsmod to see if it is loaded.
Have you booted/used windows in the meantime? It looks like some BIOS setting was altered, which is only done from our favorite OS (win+).
Then, I wonder why you have decided to do this change while having unsolved boot issues!.. ![]()
For a future-safe setup, I suggest you create and use a dedicated $ESP (vfat) partition on /dev/sda drive. Install grub manually, following grub manual or Archwiki instructions and change fstab contents properly, to make it work.
Yes, I can boot into Garuda from UEFI boot menu without any issues.
when I completed the setup and checked the restart button then the GRUB menu actually appeared and I choose Garuda from GRUB menu and then I restarted again and then this problem occured, so I don’t think the problem occured because of booting into windows.
If I am creating another EFI partition then I am unable to boot into windows from GRUB, I know because I have tried this before, the reason may be because the .efi file used to boot windows is not found by GRUB, but i don’t know what to to about that.
Should I just copy the files that are used for booting windows?
Have you ran sudo update-grub lately?
(Reboot afterwards, please.)
@Bro
Yes
Darn. Just stumbled in here prior to falling into bed. Just a shot-in-the-dark (lights are out).
This might be stupid, but try checking AHCI/RAID in BIOS. It should be AHCI.
In UEFI settings fastboot should be set to enabled or disabled?
Yes. Disable Fastboot and any related settings.
Oh, I have it enabled should I disable it now?
Sorry, I'm not here to hold your hand.
@Bro just told, DISABLE it.
