Kernel: 6.0.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=f6d41ce4-718c-4a46-a85f-af8599973e92 rw [email protected]
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: A520M-A PRO (MS-7C96) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.B0
date: 08/11/2022
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3412 high: 3599 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3599 9: 3400 10: 3400 11: 3400
12: 3400 13: 3400 14: 3400 15: 3400 16: 3400 bogomips: 108800
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Gigabyte
active: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 25:00.0
chip-ID: 1002:73ff class-ID: 0300
Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.1:4 chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
Screen-1: 0 s-res: 3926x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,right model: AOC 27G2G4
serial: <filter> built: 2022 res: 1920x1080 dpi: 82 gamma: 1.2
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: left model: Samsung SyncMaster
built: 2009 res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2
size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6600 (navi23 LLVM
14.0.6 DRM 3.48 6.0.11-zen1-1-zen) direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-1.1:4 pcie: gen: 4 chip-ID: 05a3:9331 speed: 16 GT/s
class-ID: 0102 serial: <filter> lanes: 16 bus-ID: 25:00.1
chip-ID: 1002:ab28 class-ID: 0403
bus-ID: 27:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
Device-4: Kingston HyperX SoloCast type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3:5 chip-ID: 0951:170f
Device-5: Kingston HyperX Cloud Revolver S type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 0951:16ad
Sound API: ALSA v: k6.0.11-zen1-1-zen running: yes
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-5:3
chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 2.27 TiB used: 1.06 TiB (46.6%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234110WD temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 155.25 GiB size: 155.25 GiB (100.00%)
used: 49.35 GiB (31.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 32.8 MiB (34.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 155.25 GiB size: 155.25 GiB (100.00%)
ID-4: /var/log raw-size: 155.25 GiB size: 155.25 GiB (100.00%)
ID-5: /var/tmp raw-size: 155.25 GiB size: 155.25 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
mem: 48.0 C
Processes: 405 Uptime: 1m wakeups: 0 Memory: 15.54 GiB
used: 3.45 GiB (22.2%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: 1168 pm: dpkg pkgs: 0
pm: pacman pkgs: 1162 libs: 382 tools: yay pm: flatpak pkgs: 6 Shell: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-12-01
Last full system update: 2022-12-09 ↻
I literally just want to make the contrary of this How to Get the Bootloader Grub to Remember the Last Boot Selection?. For some reason my grub comes with a option to save the last used OS, and I tried to do everything on the internet (making GRUB_DEFAULT=saved or just putting 0 and setting grub-set-default 0 (0 being my Linux)). I troubleshooted for 3 hours and the damn thing keeps saving my last OS. I just want to like use my windows, turn off the pc, come another time, and let the system boot into linux (witch it should be the default OS). Not the last used OS.
