As far as the conflict is concerned, there are several ways to approach it, see this tutorial.
Basically both (the old version of) expect and whois own those files. Strange that the problem should have been fixed now in expect.
I think that rather than using the overwrites (which I too often suggest ), you could simply temporarily remove one of the two (probably whois has less dependencies) and update.
Thanks, I added the Garuda repo and upgraded with sudo pacman -Syuu --overwrite '*'
and everything worked fine.
That isβ¦ not at all how youβre supposed to do that
If only garuda-update were used, always, by everybody. What a fantastic tool!
I'll see if I can bump the expect version to the newest one maybe to avoid this conflict, even though this is literally the first time I've ever heard of this happening
