When the computer boots up, GRUB does not show another system.
I have openSUSE and 2 more systems on another disk, but GRUB does not see only openSUSE at boot.
How to make this system visible in GRUB when loading?
??? only ???
Try
sudo update-grub
I did it. In the console, the output is normal, all operating systems are listed, there are no problems. The problem is that there is no openSUSE in the start menu in GRUB.
All other operating systems are present, only openSUSE is missing
For myself I exclude other (garuda) DE's and use custom.cfg
can you look in grub.cfg with
sudo cat /boot/grub/grub.cfg
about suse?
Thanks for your reply and help.
I checked, there is nothing on openSUSE in the output.
The fact is that I have 2 OSes installed in parallel on one logical disk - openSUSE and Fedora and, most likely, this is the reason that GRUB Garuda cannot display information about them correctly for some reason.
I think this is the reason.
efibootmgr
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0000,0002,0003,0001,0004,0005
Boot0000* garuda
Boot0001* UEFI OS
Boot0002* CD/DVD Drive
Boot0003* Hard Drive
Boot0004* UEFI OS
Boot0005* UEFI OS
Sounds more like an OpenSuse problem than a Garuda problem to me. Garuda ISO's do not come with 5 desktops and 4 OS's on them for a reason. We simply can't support that level of user complexity. Sounds like it's time to start searching online and the Grub documentation for your solution.
OK, thnks.
What could that mean?
It seems complicated for a human, so no wonder for a program. ![]()
