shmu26
October 26, 2022, 5:46pm
1
I installed a 6.0.2 kernel, in addition to my existing lts kernel
pacman -Q | grep linux 20:35:34
archlinux-appstream-data-pamac 1:20221014-1
archlinux-keyring 20220927-1
garuda-video-linux-config 1:r62.889aefa-7
lib32-util-linux 2.38.1-1
linux 6.0.2.arch1-1
linux-api-headers 5.18.15-1
linux-firmware 20220913.f09bebf-1
linux-firmware-whence 20220913.f09bebf-1
linux-headers 6.0.2.arch1-1
linux-lts 5.15.74-1
linux-lts-headers 5.15.74-1
linux-wifi-hotspot 4.4.0-1
linuxconsole 1.8.1-1
util-linux 2.38.1-1
util-linux-libs 2.38.1-1
but in order to load it, I need to go into the advanced tab of grub every time I boot, and choose it from the list. The lts kernel is listed before the 6.0.2 kernel.
What to do?
I chose this particular 6.0.2 kernel, rather than the zen version, because it seems to play better with my wifi driver.
shmu26
October 26, 2022, 5:47pm
2
Almost forgot:
garuda-inxi 20:46:50
Kernel: 6.0.2-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1ae1827d-082e-4190-8d66-84aa16e7a79c rw rootflags=subvol=@
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2208
date: 07/09/2021
Info: model: Intel Core i7-9700 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF0
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 3823 high: 4695 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4691 2: 3000 3: 4601
4: 3000 5: 4599 6: 3000 7: 4695 8: 3000 bogomips: 48016
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0300
Device-2: Microdia USB Live camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4:4 chip-ID: 0c45:636b
Device-3: USB C Video Adaptor type: USB driver: N/A bus-ID: 1-3.1.1:10
chip-ID: 25a4:9321 class-ID: 1100 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right model: VG27AQ1A
serial: <filter> built: 2020 res: 1920x1080 hz: 120 dpi: 82 gamma: 1.2
size: 596x336mm (23.46x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: primary,left
model: Samsung S24B300 serial: <filter> built: 2013 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 1-1.4:4 chip-ID: 0c45:636b
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0102 serial: <filter>
Sound API: ALSA v: k6.0.2-arch1-1 running: yes
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: Realtek 802.11ac NIC type: USB driver: rtl8821cu
bus-ID: 1-2.2:9 chip-ID: 0bda:c811 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u2u2 state: dormant mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-4.1:10 chip-ID: 0bda:8153 class-ID: 0000
IF: enp0s20f0u4u1 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-2.4:13 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.26 TiB used: 900.05 GiB (39.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
type: SSD serial: <filter> rev: K1B3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120
type: HDD rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
ID-1: / raw-size: 72.15 GiB size: 72.15 GiB (100.00%) used: 23.78 GiB
(33.0%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 34.9 MiB
(36.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 72.15 GiB size: 72.15 GiB (100.00%) used: 23.78 GiB
ID-4: /var/log raw-size: 72.15 GiB size: 72.15 GiB (100.00%) used: 23.78
GiB (33.0%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-5: /var/tmp raw-size: 72.15 GiB size: 72.15 GiB (100.00%) used: 23.78
ID-1: swap-1 type: zram size: 15.5 GiB used: 2.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A
Processes: 303 Uptime: 11m wakeups: 0 Memory: 15.5 GiB used: 4.76 GiB
(30.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1449 libs: 380
tools: pamac,paru,yay Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-09-12
Last full system update: 2022-10-26
SGS
October 26, 2022, 5:50pm
3
Did you try garuda-boot-options
system
Closed
October 28, 2022, 5:51pm
4
