How do I remove unneeded grub menus ?
like the sda1 menu
Please, follow the template.
okay i opened a new topic and followed the template
Kernel: 6.6.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=b6b92ddd-1165-4684-927f-b9ae66d45eff rw rootflags=subvol=@ rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 mitigations=off sysrq_always_enabled=1 ibt=off
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: ASUSTeK product: X540LA v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X540LA v: 1.0 serial: <superuser required> UEFI: American Megatrends
v: X540LA.303 date: 08/31/2018
ID-1: BAT0 charge: 22.1 Wh (86.7%) condition: 25.5/33.2 Wh (76.8%) power: 11.5 W volts: 10.8
min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 721
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell gen: core 5 level: v3
note: check built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
microcode: 0x2F
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1896 min/max: 500/1900 scaling: driver: intel_cpufreq governor: performance
cores: 1: 1896 2: 1896 3: 1896 4: 1896 bogomips: 15963
Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel arch: Gen-8
process: Intel 14nm built: 2014-15 ports: active: DP-1 off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 13d3:5a11 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 compositor: gnome-shell
driver: X: loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965 gpu: i915
display-ID: 0
Monitor-1: DP-1 model: Samsung SyncMaster serial: <filter> built: 2009 res: 1600x900 dpi: 92
gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes: max: 1600x900
min: 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768 dpi: 101 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast
surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2) device-ID: 8086:1616
memory: 7.47 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel HD Graphics 5500
(BDW GT2) driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:1616 surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.6.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.2 chip-ID: 10ec:8136
IF: enp2s0f2 state: down mac: <f
ilter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b723
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
discoverable: no pairing: no class-ID: c010c
Local Storage: total: 704.24 GiB used: 608.76 GiB (86.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 227N
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000LPCX-80VHAT1 size: 465.76 GiB
fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 10.44 GiB (41.9%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 9.8 GiB size: 9.8 GiB (100.00%) used: 2.3 GiB (23.5%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 10.44 GiB (41.9%) fs: btrfs
ID-5: /var/tmp raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 10.44 GiB (41.9%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 52.0 C pch: 44.5 C mobo: N/A
Fan Speeds (rpm): cpu: 2100
Processes: 272 Uptime: 12m wakeups: 0 Memory: total: 8 GiB available: 7.65 GiB
used: 2.85 GiB (37.3%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: 1207 pm: pacman pkgs: 1191 libs: 349 tools: pamac,paru pm: flatpak pkgs: 16
Client: shell wrapper v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-27
Last full system update: 2023-12-10
There is a part about search before posting help requests and what you have try to solve the problem apart from posting your garuda-inxi.
