Hello
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=60d2f9d0-6dfe-4619-8f95-bf27ec8dc438 rw rootflags=subvol=@
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: N/A
Mobo: HP model: 81EC v: 61.59 serial: <filter> UEFI: Insyde v: F.46
date: 11/16/2018
ID-1: BAT1 charge: 1.4 Wh (100.0%) condition: 1.4/32.1 Wh (4.5%)
volts: 16.5 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: N/A
Info: model: Intel Core i5-6200U socket: U3E1 bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2732 high: 2746 min/max: 400/2800 base/boost: 2200/8300
ext-clock: 100 MHz cores: 1: 2740 2: 2746 3: 2703 4: 2739 bogomips: 19200
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu pcie:
gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Chicony HP TrueVision HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b56c class-ID: 0e02 serial: <filter>
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: intel,radeon unloaded: modesetting alternate: fbdev,vesa gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0687 built: 2015
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.0.0
direct render: Yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard
bus-ID: 03:00.0 chip-ID: 14e4:4365 class-ID: 0280
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4:2 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 931.51 GiB used: 72.72 GiB (7.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100M
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 2.6
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1U temp: 43 C
SMART: yes state: enabled health: PASSED on: 234d 9h cycles: 3156
Old-Age: g-sense error rate: 3042 Pre-Fail: reallocated sector: 100
threshold: 50
ID-1: / raw-size: 81.72 GiB size: 81.72 GiB (100.00%)
used: 62.09 GiB (76.0%) fs: btrfs block-size: 4096 B dev: /dev/sda6
maj-min: 8:6
ID-2: /boot/efi raw-size: 102 MiB size: 96 MiB (94.12%)
used: 41.8 MiB (43.6%) fs: vfat block-size: 512 B dev: /dev/sda2
maj-min: 8:2
ID-3: /home raw-size: 81.72 GiB size: 81.72 GiB (100.00%)
maj-min: 8:6
ID-4: /var/log raw-size: 81.72 GiB size: 81.72 GiB (100.00%)
maj-min: 8:6
ID-5: /var/tmp raw-size: 81.72 GiB size: 81.72 GiB (100.00%)
maj-min: 8:6
ID-1: swap-1 type: zram size: 3.6 GiB used: 866.2 MiB (23.5%)
System Temperatures: cpu: 29.8 C pch: 41.5 C mobo: 27.8 C gpu: radeon
temp: 42.0 C
Processes: 243 Uptime: 33m wakeups: 2 Memory: 3.6 GiB
used: 2.51 GiB (69.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1201 lib: 298
inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-01-07
Last full system update: 2022-03-31
Is partially upgraded: Yes
I have Garuda xfce in another drive I cannot boot into it. I see the boot entry but it shows an error on booting. I did the os-prober to get the entry.
