Συνέχιση της συζήτησης από το How to enable os prober in garuda:
I would suggest a different approach on the hook.
- Current
if grep -Fxq "GRUB_DISABLE_OS_PROBER=false" /etc/default/grub ; then
echo "os-prober already enabled"
else echo "GRUB_DISABLE_OS_PROBER=false" >> /etc/default/grub
fi
- Proposed
if test ! `grep -q "^GRUB_DISABLE_OS_PROBER=" /etc/default/grub` ; then
echo "
#Change this to GRUB_DISABLE_OS_PROBER=true to disable os-prober
echo "os-prober was enabled by default"
fi
Reason
- We should not force a system change made by the user without reason.
- If a user has disabled os-prober, the current hook changes this to enabled
- A hook message for a useless info will eternally inform about it for a change that was not made
- The proposed hook checks for the enabled parameter without the value. If it was set (by the user, since was not there by default), we let it unchanged. If it is not set (as from package default), we add the previous default, with a classic note for its usage.
And... this hook should be bound to os-prober package, not grub, because this way... it makes sense.
I'll do the change later
