When i try opening gwe i get a nv/controll x extension not found error, but i have the proprietary drivers.
Im running a optimus device and have tried installing optimus-manager to no avail.
Welcome
Please.
Just follow the template.
what template, im afraid i didn't know about its existence
The one you just delete.
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
Kernel: 6.4.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=71dc5430-46fb-4bad-bae3-a381163bad51 rw rootflags=subvol=@
Desktop: wayfire v: 0.7.5 vt: 1 dm: greetd Distro: Garuda Linux
Type: Laptop System: LENOVO product: 82JU v: Legion 5 15ACH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 15ACH6H
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: <superuser required> UEFI: LENOVO v: GKCN50WW date: 11/24/2021
ID-1: BAT0 charge: 82.1 Wh (98.9%) condition: 83.0/80.0 Wh (103.7%)
power: 7.8 W volts: 17.6 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: charging cycles: 5
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1574 high: 3200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1198 2: 1200
3: 1200 4: 1195 5: 1200 6: 1200 7: 1200 8: 1200 9: 3200 10: 3200 11: 1200
12: 1200 13: 3200 14: 1200 15: 1200 16: 1200 bogomips: 102216
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2560 class-ID: 0300
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 38.0 C
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: wayfire v: 0.7.5 driver: gpu: amdgpu display-ID: 1
Monitor-1: eDP-1 model: AU Optronics 0xb69b built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.10-zen1-1-zen) direct-render: Yes
Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.10-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: N/A modules: rtw_8852ae pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0bda:4852
address: <filter>
Local Storage: total: 476.94 GiB used: 28.11 GiB (5.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11190001 temp: 37.9 C scheme: GPT
used: 28.11 GiB (5.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 13.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 39.0 C
Processes: 344 Uptime: 9m wakeups: 1 Memory: total: 16 GiB note: est.
available: 13.51 GiB used: 2.31 GiB (17.1%) Init: systemd v: 254
pm: pacman pkgs: 1568 libs: 477 tools: pamac,paru pm: flatpak pkgs: 0
Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.28
System install date: 2023-08-07
Last full system update: 2023-08-13
also the spaces between letters in some windows are irregular, like words will look like this: "H el low orl d", which i think is due to the font
another this that goes wrong is when trying to edit the keyboard layout it doesnt actually change
What does the error exactly say? Paste it into the thread if you can.
What did you try? What went wrong?
Since you have a laptop, consider using prime-run
for offloading to the dGPU. This method has many advantages compared to optimus-manager or optimus-switch. Read through this short article to learn more: Switching between integrated and dedicated graphics | Garuda Linux wiki
What applications are you noticing this odd font rendering in?
Describe your method for attempting to change the keyboard layout.
- Greenwithenvy absolutely needs en_US as locale it’s hardcoded to not work without it. You can look here.
- Even after changing locale and launching it from terminal you won’t be able to use it since currently gwe has some issue that’s making it unable to launch it at all. It’s an open issue on gitlab.
i guess it doesnt support wayland which is what im using
the terminal, conky and other terminal basedd apps, i suspect (ඞ) it is due to the font “conflicting” with the letter spacing the terminal has
garuda settings manager > keyboard settings > chose the correct layout for the keyboard > click apply > input correct password
This seems like the crux of the issue. It seems unlikely you will get this working on Wayfire. Try a DE that can run an X session like KDE or XFCE.
im sorry but can you translate that to a slightly more understandable english ( english nor linux are my first languages )
The meaning of this sentence is: “This looks like the most important part of the problem.”
The software you are trying to run is not compatible with the Wayland display protocol, which is what Wayfire uses. My suggestion is to try a desktop environment (DE) which can run the Xorg display protocol instead.
XFCE, Mate, and Cinnamon are DEs that run only the Xorg display protocol, for example.
KDE and Gnome can run either Wayland or Xorg, so could probably be made to work.
Wayfire can run only Wayland, so for this application will not work.
