Gray screen after waking up
Hello. So I’ve noticed strange issue for me. I left my laptop for a few minutes, with music on. When I came back my PC was asleep, and I tried to wake it up by pressing a key on keyboard. It turned gray, I could hear the music from my headphones, but nothing worked. Not even tty’s.
My garuda-inxi:
  Kernel: 6.10.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=3c23d55d-747f-4b09-8131-7f92af2c69fd rw rootflags=subvol=@
  Desktop: GNOME v: 46.4 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Garuda base: Arch Linux
  Type: Laptop System: LENOVO product: 82RG v: Legion 5 Pro 16ARH7H
    serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ARH7H
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
    serial: <superuser required> part-nu: LENOVO_MT_82RG_BU_idea_FM_Legion 5
    Pro 16ARH7H uuid: <superuser required> UEFI: LENOVO v: JUCN66WW
    date: 05/31/2024
  ID-1: BAT0 charge: 61.4 Wh (79.0%) condition: 77.7/80.0 Wh (97.2%)
    volts: 16.0 min: 15.4 model: BYD L21B4PC0 type: Li-poly serial: <filter>
    status: not charging cycles: 107
  Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404105
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 672 high: 1979 min/max: 400/4785 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1979 2: 400 3: 1967
    4: 400 5: 400 6: 400 7: 400 8: 1606 9: 400 10: 400 11: 400 12: 400 13: 400
    14: 400 15: 400 16: 400 bogomips: 102206
  Device-1: NVIDIA GA104M [Geforce RTX 3070 Ti Laptop GPU] vendor: Lenovo
    driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    off: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:24e0
  Device-2: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3,
    DP-4, DP-5, DP-6, Writeback-1 bus-ID: 34:00.0 chip-ID: 1002:1681
    class-ID: 0300 temp: 52.0 C
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 mapped: DP-4 note: disabled model: BOE Display 0x0a9b
    built: 2020 res: 2560x1600 dpi: 4064 gamma: 1.2 size: 16x10mm (0.63x0.39")
    diag: 406mm (16") ratio: 16:10 modes: 2560x1600
  API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3070 Ti Laptop GPU driver: nvidia v: 555.58.02
    device-ID: 10de:24e0 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 24.1.6-arch1.1
    device-ID: 1002:1681 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
    (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM
  Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.5
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.6
  API: ALSA v: k6.10.5-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
    port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
    driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 3-3:4 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
  Local Storage: total: 953.87 GiB used: 66.02 GiB (6.9%)
    model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: CL1QGXA7 temp: 47.9 C scheme: GPT
  ID-1: / raw-size: 106.45 GiB size: 106.45 GiB (100.00%)
    used: 65.96 GiB (62.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
    used: 59.5 MiB (61.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 106.45 GiB size: 106.45 GiB (100.00%)
  ID-4: /var/log raw-size: 106.45 GiB size: 106.45 GiB (100.00%)
  ID-5: /var/tmp raw-size: 106.45 GiB size: 106.45 GiB (100.00%)
  ID-1: swap-1 type: zram size: 14.81 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 63.0 C mobo: 52.0 C
  GPU: device: nvidia screen: :1.0 temp: 51 C device: amdgpu temp: 52.0 C
  Memory: total: 16 GiB note: est. available: 14.82 GiB used: 4.47 GiB (30.2%)
  Processes: 420 Power: uptime: 15m states: freeze,mem,disk suspend: s2idle
    image: 5.88 GiB services: gsd-power, power-profiles-daemon, upowerd
  Packages: pm: pacman pkgs: 1342 libs: 410 tools: paru,yay Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
    inxi: 3.3.35
  System install date:     2024-08-19
  Last full system update: 2024-08-20 ↻
using a nvidia card could be the issue here.
Open a terminal and enter the following commands.
#commands to fix suspending computer
sudo micro /etc/modprobe.d/nvidia-preserve-video-memory.conf
#paste the line below
options nvidia NVreg_PreserveVideoMemoryAllocations=1
#press Ctrl s, and then Ctrl q, to save and close the file.
#activate suspend services.
sudo systemctl enable nvidia-suspend.service
sudo systemctl enable nvidia-hibernate.service
sudo systemctl enable nvidia-resume.service
#now reboot.
reboot.
See how that works.
sudo systemctl enable --now nvidia-suspend.service
sudo systemctl enable --now nvidia-hibernate.service
sudo systemctl enable --now nvidia-resume.service
Just a hint.
With
--now
you can save yourself the reboot, at least that was always the case with my commands so far.
The proof of the pudding is in the eating. :wink:
Yep worked ig. Thanks a lot <3
What does --now exactly do? :smiley:
The enable subcommand doesn’t start a service, it only marks it to start automatically at boot.
To enable and start a service at the same time, use the --now option.
As Schabowski said some years ago: ist das sofort, unverzüglich is that immediately, without delay :slight_smile:
