Graphics card gets to 100% in two specific games, causing huge FPS drop and stream halt
Hi folks.
So, back in this other topic I mentioned that I was then able to play Driftland for more than 3 hours without any significant problems, except for some minor around-a-minute-long hiccups that made FPS drop from steady 60 to around 4-5.
So I decided to go one step further and see if I could stream now. And turns out I mostly can. Did a few runs in the past few days, and also today. Played Bayonetta (if you wanna check it out), Noita, Destiny of Fate, Jagged Alliance, Headsnatchers, Gene Shift Auto… and Fort Triumph. And here’s where hell broke loose.
The same hiccups that happened with Driftland decided to show up again on Fort Triumph… but this seems to be related to something over using (???) the graphics card. Along with the FPS drop, I was monitoring GPU usage with nvtop and saw the GPU % go up to 100%, and when it was over OBS had halted streaming with an error message saying that
 187   │ 22:04:00.742: [NVIDIA NVENC H.264 (FFmpeg) encoder: 'simple_video_stream'] Encoding queue duration surpassed 5 seconds, terminating encoder
 188   │ 22:04:00.742: Error encoding with encoder 'simple_video_stream'
 189   │ 22:04:00.742: Video stopped, number of skipped frames due to encoding lag: 1057/430015 (0.2%)
 190   │ 22:04:00.742: [rtmp stream: 'simple_stream'] Encoder error, disconnecting
you folks have any tips on what I should look into that could be causing these two games to make this huge GPU consumption?
  Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=468e3250-834f-4678-85b1-f50f268e557d rw rootflags=subvol=@
    quiet console=tty0 console=ttyS0,115200n8 cryptomgr.notests
    initcall_debug intel_iommu=igfx_off kvm-intel.nested=1 no_timer_check
    noreplace-smp page_alloc.shuffle=1 rcupdate.rcu_expedited=1
    rootfstype=ext4,btrfs,xfs,f2fs tsc=reliable rd.udev.log_priority=3
    vt.global_cursor_default=0
    resume=UUID=92d5bc58-440e-4eab-9f01-4fa35d34e02b loglevel=3 rw ibt=off
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
  Type: Laptop System: Dell product: G5 5590 v: N/A
  Mobo: Dell model: 0F3T2G v: A00 serial: <superuser required> UEFI: Dell
    v: 1.22.0 date: 11/10/2022
  ID-1: BAT0 charge: 45.4 Wh (100.0%) condition: 45.4/60.0 Wh (75.6%)
    volts: 16.6 min: 15.2 model: SMP DELL JJPFK87 type: Li-poly serial: <filter>
    status: full
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 4095 high: 4108 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4100 2: 4100 3: 4100
    4: 4096 5: 4106 6: 4031 7: 4100 8: 4104 9: 4100 10: 4100 11: 4100 12: 4108
    bogomips: 62399
    ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:671f
    class-ID: 0e02
  Screen-1: 0 s-res: 4480x2160 s-dpi: 114 s-size: 999x482mm (39.33x18.98")
    s-diag: 1109mm (43.67")
  Monitor-1: DP-0 pos: primary,top-right res: 2560x1080 hz: 60 dpi: 81
    size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
  Monitor-2: HDMI-0 pos: bottom-r res: 2560x1080 hz: 60 dpi: 96
    size: 677x290mm (26.65x11.42") diag: 736mm (29") modes: N/A
  Monitor-3: eDP-1-1 pos: bottom-l res: 1920x1080 hz: 144 dpi: 142
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.113.01
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.3.264 layers: 14 device: 0 type: integrated-gpu
    name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 2060 driver: nvidia v: 535.113.01
    device-ID: 10de:1f11 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
  Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-3: Generalplus USB Audio Device
    lanes: 1 mode: 1.1 bus-ID: 1-4.1:4 chip-ID: 1b3f:2008 class-ID: 0300
  Device-4: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.5:8 chip-ID: 0bda:4014
  API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api with: aoss
  Device-1: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
  IF: enp60s0 state: down mac: <filter>
    vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 3d:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 75.0 C
  IF: wlp61s0 state: down mac: <filter>
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.2:3
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 0cf3:e007
  Local Storage: total: 1.14 TiB used: 473.82 GiB (40.5%)
    model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 20240012 temp: 60.9 C scheme: GPT
    model: WD10SPZX-75Z10T3 size: 931.51 GiB block-size: physical: 4096 B
    fw-rev: 4514 scheme: GPT
  ID-1: / raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
    used: 89.53 GiB (40.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
  ID-4: /var/log raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
  ID-5: /var/tmp raw-size: 221.19 GiB size: 221.19 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.31 GiB used: 4.08 GiB (26.6%)
  ID-2: swap-2 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 84.0 C pch: 86.0 C mobo: N/A gpu: nvidia
    temp: 83 C
  Processes: 381 Uptime: 4h 0m wakeups: 13 Memory: total: 16 GiB note: est.
  available: 15.31 GiB used: 6.79 GiB (44.3%) Init: systemd v: 254
  Packages: 1945 pm: pacman pkgs: 1937 libs: 488
  tools: gnome-software,octopi,pamac,paru,yay pm: flatpak pkgs: 8 Shell: Zsh
  v: 5.9 running-in: kitty inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2023-04-01
  Last full system update: 2023-10-20
I’m gonna up this just this once, it’s not only those two games, it’s not even only same-engine games, like say Unity or Unreal.
It’s also apparently random as hell, because yesterday I left Omensight open for the whole day and whenever job#2 gave me a break I would play it… and I was playing nicely.
Then, when night fell, every now and then it’d happen. And the only thing every time the FPS dropped had in common was GPU usage at 100%…
also, not only the game FPS’ dropped, but performance in the whole system all around. Moving the mouse would be affected, typing would be affected, everything.
