Hey guys-
After my most recent system update, I’ve been having issues with kwin when playing games. My entire display will freeze seemingly at random, making most games unplayable. Checking garuda assistant and I noticed these errors in the “other diagnostics” tab:
May 19 20:29:06 Lettuce-Desktop kwin_wayland[40580]: kwin_scene_opengl: Can't enable invalid framebuffer object!
May 19 20:29:06 Lettuce-Desktop kwin_wayland[40580]: kwin_scene_opengl: Invalid framebuffer status: "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Looking this error up brought up one problem that may be related: [SOLVED?] Kde-Plasma system tray broken. / Applications & Desktop Environments / Arch Linux Forums
The fix listed in the thread wasn’t applicable to my problem however. Has anyone else experienced this?
For now I’m just going to revert to a snapshot before I updated so I can keep playing games for the time being.
Thanks in advance for any responses.
-Lettuce
Please provide garuda-inxi
and also , are you on wayland ?
nepti
20 May 2024 09:10
3
Do you have the same issue on x11?
garuda-inxi:
Kernel: 6.8.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=abecce04-e79f-405d-969b-540110b145d8 rw rootflags=subvol=@
quiet resume=UUID=4cc721d1-5ee8-4a1c-938e-e121947517a5 loglevel=3 ibt=off
Type: Desktop System: Micro-Star product: MS-7A34 v: 4.0
Mobo: Micro-Star model: B350 GAMING PLUS (MS-7A34) v: 4.0
UEFI: American Megatrends v: M.HS date: 11/04/2021
Info: model: AMD Ryzen 5 1600X bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3685 high: 3700 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3696 2: 3694
3: 3697 4: 3694 5: 3636 6: 3700 7: 3696 8: 3695 9: 3700 10: 3682 11: 3636
12: 3700 bogomips: 86390
Device-1: Intel DG2 [Arc A770] vendor: Acer Incorporated ALI driver: i915
v: kernel alternate: xe arch: Gen-12.7 code: Alchemist
process: TSMC n6 (7nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1
ports: active: DP-1,DP-3 empty: DP-2, DP-4, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 28:00.0 chip-ID: 8086:56a0 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-2:2
Monitor-1: DP-1 model: Dell P2412H serial: <filter> built: 2012
res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-3 model: Acer XF243Y P serial: <filter> built: 2023
res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A770 Graphics (DG2)
device-ID: 8086:56a0 memory: 15.53 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: Intel
Arc A770 Graphics (DG2) driver: mesa intel v: 24.0.6-arch1.2
device-ID: 8086:56a0 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.6-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Creative Labs CA0106/CA0111 [SB Live!/Audigy/X-Fi Series]
driver: snd_ca0106 v: kernel bus-ID: 22:00.0 chip-ID: 1102:0007
class-ID: 0401
Device-2: Intel DG2 Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 29:00.0 chip-ID: 8086:4f90 class-ID: 0403
Device-3: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-4: C-Media Antlion USB adapter
lanes: 1 mode: 1.1 bus-ID: 4-9:3 chip-ID: 0d8c:002c class-ID: 0300
Device-5: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.8.9-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 23:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp35s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.64 TiB used: 1.2 TiB (32.9%)
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000LM009-1R9174
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 0001 scheme: MBR
ID-1: / raw-size: 914.1 GiB size: 914.1 GiB (100.00%)
used: 723.46 GiB (79.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 914.1 GiB size: 914.1 GiB (100.00%)
ID-4: /var/log raw-size: 914.1 GiB size: 914.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.1 GiB size: 914.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 1.25 GiB (8.0%)
ID-2: swap-2 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 50.5 C mobo: 36.0 C
Fan Speeds (rpm): fan-1: 1515 fan-2: 1950 fan-3: 826 fan-4: 0 fan-5: 808
fan-6: 978
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.33
Memory: total: 16 GiB available: 15.56 GiB used: 8.33 GiB (53.5%)
Processes: 392 Power: uptime: 1d 1h 55m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.21 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Packages: 1779 pm: pacman pkgs: 1749 libs: 523 tools: yay pm: flatpak
pkgs: 30 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
System install date: 2023-12-05
Last full system update: 2024-05-08
Yes, I’m on wayland
X11 isn’t an option for me since I have 2 monitors of different refresh rates.
nepti
21 May 2024 09:18
6
Lettuce:
Lettuce:
frameworks v: 6.1.0
Please update your system and check if that helps.
First try out the lts kernel by running sudo pacman -S linux-lts
and reboot. If that doesn’t help , at least try X11 to see if it even works
That’s the reason I’m making this post. This is the system that works currently. I’m not encountering the issue with the snapshot from May 8th, but when I update to the most recent versions of all the software on my system, I have the problem described.
Even if X11 works, I can’t use it on my system. Yes it would function but since I have 2 displays with different refresh rates (and I like to use VRR in games as well) it wouldn’t be viable.
Lts Kernel ? Did it work ?
May 21 15:34:02 Lettuce-Desktop kwin_wayland[5168]: kwin_scene_opengl: Invalid framebuffer status: "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
May 21 15:34:02 Lettuce-Desktop kwin_wayland[5168]: kwin_scene_opengl: Can't enable invalid framebuffer object!
Saw this a couple more times while playing DRG but it hasn’t come back, so tentatively this was the solution. May I ask why did you think of this as the culprit?
Thanks.
-Lettuce
Zen kernel sometimes behaves very weirdly as it did with me in the past ,freezing, graphical anomalies, what not. So I thought you might be having the same issues. LTS kernel is usually the best bet for stability and speed.
Thank you. Appreciate your help.
system
Closed
25 May 2024 03:01
14
