At around 55 minutes after booting up a game, the utilization and power of the GPU will drop significantly in response to moving the mouse or inputing keys.
I am using Goverlay/Mangohud to monitor this performance issue in game and proton experimental for game compatibility.
The Problem: The GPU performance is running at 2562mhz, drawing 301w at 100% utilization around 71c. And from 55 minutes more or less exactly into starting a game, moving the mouse or inputing any keys will drop the GPU performance to between 23mhz and 1400mhz, dropping power draw to 107w or lower and dropping usage down to around 64%.
The effect on performance is a drop from around 114fps down to 37fps with the frametime showing it is rapidly going between 6.5ms and 69.1ms while an input is held.
Rebooting the game brings performance back to normal, the issue starts again after another 55 minutes.
Not moving the mouse or holding any keys the game will run normal.
Moving the mouse outside the game when tabbed or in other programs doesnt cause stuttering or any power/utilization drops after this 55 minute window.
This issue affects all games in my steam libary.
Inputting say, W to walk forward will begin the aforementioned performance drop, but if another key is pressed and released while the W is still held, performance will normalise despite the input. But if W is released and reinputted it will begin dropping performance again.
The timer of 55 minutes I consistently timed on a stopwatch from the moment the game opened a window until inputs dropped performance.
I could not really figure this next part out fully, I found being tabbed out for 55 minutes and coming back to the game to do more tests on the issue, I found the game would still be performing normally. I believe the game window has to be in focus for around 55 minutes for the performance to drop. I could not confirm the full extent of this behaviour.
My linux power settings are set to performance and I do not run any overlays in game normally outside testing this current issue. Do not have much technical experience with linux or troubleshooting in general, any help appreciated.
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b3976b77-94c4-4857-b98a-9f42ea516c54 rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: X670 GAMING X AX v: x.x
Megatrends LLC. v: F30 date: 05/22/2024
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4939 min/max: 545/5050 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4939 2: 4939 3: 4939
4: 4939 5: 4939 6: 4939 7: 4939 8: 4939 9: 4939 10: 4939 11: 4939 12: 4939
13: 4939 14: 4939 15: 4939 16: 4939 bogomips: 134140
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Sapphire PULSE driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: Realtek Streamplify CAM driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 9-1.3:3
chip-ID: 0bda:0567 class-ID: 0102 serial: <filter>
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Dell AW3423DWF serial: <filter> built: 2022 res:
mode: 3440x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2
size: 800x337mm (31.5x13.27") diag: 868mm (34.2") modes: max: 3440x1440
min: 720x400
navi31 LLVM 19.1.7 DRM 3.59 6.12.10-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
lanes: 16 bus-ID: 18:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: RODE Microphones NT-USB driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 19f7:0003 class-ID: 0300
Device-4: Realtek Streamplify CAM driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 11:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp17s0 state: down mac: <filter>
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 0e8d:0616
Local Storage: total: 5 TiB used: 1.19 TiB (23.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: TeamGroup
model: T-CREATE TM8FPM002T size: 1.82 TiB block-size: physical: 512 B
fw-rev: ELFMB0.6 temp: 42.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: TeamGroup
fw-rev: ELFMB0.6 temp: 43.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
used: 338.6 GiB (72.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 26.2 MiB (8.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 30.8 GiB used: 1.03 GiB (3.4%) priority: 100
System Temperatures: cpu: 58.5 C mobo: 32.0 C gpu: amdgpu temp: 48.0 C
mem: 63.0 C
Memory: total: 32 GiB note: est. available: 30.8 GiB used: 8.14 GiB (26.4%)
Processes: 421 Power: uptime: 2h 53m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.3 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1836 libs: 532 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2023-06-17
Last full system update: 2025-02-04 ↻
