Is a picture worth 1000 words? Not sure what other information would be helpful.
(*Now showing up but not populating)
(** Showed up and disappeared after)
Much appreciated.
Kernel: 6.14.11-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 15.1.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=ae2423f0-deb7-4c93-839e-8c1e50dc6871 rw rootflags=subvol=@
quiet rd.luks.uuid=c81a926c-abfd-44bd-88f3-7903c6806431
rd.luks.uuid=b2e08dcf-2495-47de-9445-b93a2d46c4bc
resume=/dev/mapper/luks-b2e08dcf-2495-47de-9445-b93a2d46c4bc loglevel=3
Desktop: KDE Plasma v: 6.4.3 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Mini-pc System: Micro (HK) Tech product: Venus series v: N/A
Mobo: Shenzhen Meigao Equipment model: F7BSC serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.09
date: 11/20/2023
Device-1: hidpp_battery_0 model: Logitech Illuminated Living-Room Keyboard
K830 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
microcode: 0xA704107
Speed (MHz): avg: 2149 min/max: 400/5263 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2149 2: 2149 3: 2149
4: 2149 5: 2149 6: 2149 7: 2149 8: 2149 9: 2149 10: 2149 11: 2149 12: 2149
13: 2149 14: 2149 15: 2149 16: 2149 bogomips: 127762
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1 bus-ID: c5:00.0
chip-ID: 1002:15bf class-ID: 0300 temp: 84.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3440x2880
display-ID: 0
Monitor-1: HDMI-A-1 pos: bottom model: Samsung S34CG50 serial: <filter>
built: 2024 res: mode: 3440x1440 hz: 100 scale: 100% (1) dpi: 109 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 3440x1440
min: 720x400
Monitor-2: HDMI-A-2 pos: primary,top model: Samsung S34CG50
serial: <filter> built: 2024 res: mode: 3440x1440 hz: 100 scale: 100% (1)
dpi: 109 gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: max: 3440x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
phoenix LLVM 20.1.8 DRM 3.61 6.14.11-hardened1-1-hardened)
device-ID: 1002:15bf memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon 780M Graphics (RADV PHOENIX) driver: mesa radv v: 25.1.6-arch1.1
device-ID: 1002:15bf surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.6-arch1.1 (LLVM
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: c5:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: c5:00.5 chip-ID: 1022:15e2 class-ID: 0480
bus-ID: c5:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.11-hardened1-1-hardened status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 8087:0032
Local Storage: total: 2.05 TiB used: 35.25 GiB (1.7%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 55.9 C
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 60.9 C scheme: GPT
ID-1: / raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
used: 35.25 GiB (17.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c81a926c-abfd-44bd-88f3-7903c6806431
used: 776 KiB (0.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:7
ID-3: /home raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-4: /var/log raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-5: /var/tmp raw-size: 200.52 GiB size: 200.52 GiB (100.00%)
ID-1: swap-1 type: partition size: 32.07 GiB used: 0 KiB (0.0%)
mapped: luks-b2e08dcf-2495-47de-9445-b93a2d46c4bc
ID-2: swap-2 type: zram size: 29.15 GiB used: 6 GiB (20.6%) priority: 100
System Temperatures: cpu: 75.0 C mobo: N/A gpu: amdgpu temp: 85.0 C
Memory: total: 32 GiB note: est. available: 29.15 GiB
used: 24.85 GiB (85.2%)
Processes: 455 Power: uptime: 2h 57m states: freeze,mem suspend: s2idle
wakeups: 1 services: org_kde_powerdevil, power-profiles-daemon, upowerd
Packages: pm: pacman pkgs: 1489 libs: 461 tools: octopi,paru Compilers:
inxi: 3.3.38
Garuda (2.7.3-2):
System install date: 2025-05-30
Last full system update: 2025-07-25
Failed units: systemd-hibernate-resume.service
