Running pacman -Syu has been giving me this error since last night. Please help me fix this
error: GPGME error: No data
error: failed to synchronize all databases (unexpected error)
garuda-inxi output
Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=8dcf10f3-a757-48a0-be6b-617f5baccb56 rw [email protected]
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 info: latte-dock
Type: Laptop System: LENOVO product: 80QQ v: Lenovo ideapad 100-15IBD
serial: <superuser required> Chassis: type: 10
v: Lenovo ideapad 100-15IBD serial: <superuser required>
Mobo: LENOVO model: Nano 5B6 v: NO DPK serial: <superuser required>
UEFI-[Legacy]: LENOVO v: E0CN45WW date: 01/13/2016
ID-1: BAT0 charge: 15.0 Wh (100.0%) condition: 15.0/30.1 Wh (50.0%)
volts: 16.1 min: 14.4 model: ANYO 15S4A01 type: Li-poly
serial: <filter> status: Full
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1489 high: 1847 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 906 2: 1552
3: 1847 4: 1654 bogomips: 15964
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: IMC Networks Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 2-6:3 chip-ID: 13d3:5744 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver:
X: loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
s-diag: 414mm (16.3")
Monitor-1: eDP1 mapped: eDP-1 model: LG built: 2015 res: 1366x768
hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.4x7.5")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Lenovo driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:b723 class-ID: 0280
Device-1: Realtek RTL8723B Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-7:4 chip-ID: 0bda:b728 class-ID: e001 serial: <filter>
Local Storage: total: 409.89 GiB used: 26.98 GiB (6.6%)
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MK3276GSX
size: 298.09 GiB block-size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1X
scheme: MBR
ID-1: / raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
used: 26.98 GiB (24.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-3: /var/log raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-4: /var/tmp raw-size: 111.79 GiB size: 111.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.75 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 62.0 C mobo: N/A
Processes: 216 Uptime: 9m wakeups: 1 Memory: 3.75 GiB
used: 1.78 GiB (47.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1521 lib: 365 Shell: fish
v: 3.3.1 running-in: alacritty inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-02-13
Last full system update: 2022-03-17
