Hello everyone.
So I decided to get myself a Radeon Rx 7800 XT, on launch, because getting something on launch is always a good idea … ![]()
The Graphic card is shown as AMD Device 747e. Works, but is missing some functionality. I guess I’ll have to wait for a kernel update…
My Problem is that, since I installed the card, my system fails to shutdown: everything closes as normal but, when it should turn off, It restarts instead. Choosing shutdown from the boot menu always works, but if Linux loads, It will just restart.
I also noticed that allowing the system to go into power saving, causes it to crash.
I hope you might be able to help me. I’ll will also post if the problem goes away after an update or something.
Thanks in advance. ![]()
Kernel: 6.5.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=810cddd0-3d54-45f7-88fa-84f8b12b1038 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-I GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 5003
date: 02/03/2023
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4034 high: 4100 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4099 2: 4090
3: 4099 4: 4098 5: 4099 6: 4100 7: 4099 8: 4100 9: 3600 10: 4091 11: 4086
12: 3600 13: 4100 14: 4095 15: 4100 16: 4093 bogomips: 115205
Device-1: AMD vendor: Tul / PowerColor driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1
bus-ID: 09:00.0 chip-ID: 1002:747e class-ID: 0300
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 046d:0825
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: bottom-l model: AOC 2590G4
serial: <filter> built: 2019 res: 1920x1080 dpi: 90 gamma: 1.2
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
Monitor-2: DP-2 mapped: DisplayPort-1 pos: primary,top-right
model: MSI MAG274QRF-QD serial: <filter> built: 2021 res: 2560x1440 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: AMD Radeon Graphics
(gfx1101 LLVM 16.0.6 DRM 3.54 6.5.3-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab30
Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Device-4: Logitech G432 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 3-3:4 chip-ID: 046d:0a9c class-ID: 0300
API: ALSA v: k6.5.3-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: ASUSTek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:6 chip-ID: 0b05:185c
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 3.66 TiB used: 2.83 TiB (77.2%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
fw-rev: 4B2QEXM7 temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: S0118C temp: 37.9 C
model: WD10SPZX-00Z10T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
used: 861.18 GiB (90.3%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.53 GiB used: 1.68 GiB (10.8%)
System Temperatures: cpu: 51.0 C mobo: 58.0 C gpu: amdgpu temp: 52.0 C
mem: 66.0 C
Fan Speeds (rpm): cpu: 665 case-1: 635 gpu: amdgpu fan: 889
Power: 12v: 9.97 5v: N/A 3.3v: N/A vbat: 3.23 gpu: amdgpu watts: 58.00
Processes: 367 Uptime: 28m wakeups: 0 Memory: total: 16 GiB
available: 15.53 GiB used: 5.54 GiB (35.6%) Init: systemd v: 254
Packages: 2156 pm: pacman pkgs: 2144 libs: 602 tools: octopi,paru,yay
pm: flatpak pkgs: 12 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.29
System install date: 2022-06-25
Last full system update: 2023-09-18
Failed units: fancontrol.service
PS1: Found someone with the same Graphic card not fully recognized in Arch, nothing about the shutdown problem (nor answers either…). Amd Rx 7800 xt working but not showing up as the amd rx 7800 xt / Kernel & Hardware / Arch Linux Forums
PS2: Read about the reset instead Shutdown being a motherboard bug in some other place (lost the link). This motherboard never showed this behavior before. The solutions suggested involved messing with the USB configuration in the BIOS. Didn’t work for me.
