I'm using the KDE Dragonized Gaming Edition.
When I load Google Messages in Firedragon, the QR code that's used to login is obscured. I can see the QR code for a brief instant while the page loads, but it's quickly replaced by lines or a lattice that completely obscures the QR code. Thus, I can't login to Google SMS on the desktop.
What can I do about this?
What other info should I provide to help diagnose this?
Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=709fd02c-3a44-4a1d-9151-544417107d13 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop System: Micro-Star product: MS-7C02 v: 1.0 serial: <filter>
Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <filter> UEFI: American Megatrends v: 3.50 date: 11/07/2019
Device-1: hidpp_battery_0
model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 115199
Speed: 3593 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3593 2: 3885 3: 3610 4: 3603 5: 3593 6: 3593 7: 3597 8: 3573 9: 3601
10: 3598 11: 3601 12: 3604 13: 3602 14: 3599 15: 3595 16: 3779
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
conditional, RSB filling
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 26:00.0
chip-ID: 10de:2503 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 92 s-size: 1237x393mm (48.7x15.5")
s-diag: 1298mm (51.1")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DP-0 res: 2560x1440 dpi: 93 size: 697x392mm (27.4x15.4")
diag: 800mm (31.5")
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 26:00.1 chip-ID: 10de:228e class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
Device-3: Razer USA Razer BlackShark V2 Pro type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-9:4 chip-ID: 1532:0528
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
Local Storage: total: 2 TiB used: 191.51 GiB (9.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Intel model: SSDPE2MX012T7
size: 1.09 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: MDV1NX27 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
used: 191.51 GiB (20.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
ID-4: /var/log raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 358 Uptime: 26m wakeups: 5 Memory: 31.3 GiB
used: 3.98 GiB (12.7%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1754 lib: 531 Shell: fish v: 3.3.1
running-in: terminator inxi: 3.3.06
I don't know where to begin diagnosing the issue. Any help is appreciated.
Thanks!
