Hi, I just wanted to share my latest Garuda Gnome / XFCE adventures.
I had been using my work laptop during the weekend and, as usual, I updated all packages through garuda-update. When I booted my laptop this morning, GDM was misbehaving a bit (it showed me a gray screen with volume control and the possibility to shutdown/restart, but no login prompt) and to make matters worse, I was unable to start another TTY in order to investigate or fix the issue.
After a while I decided to use one of the latest ISOs for live boot / rescue purposes. Unfortunately, the largest USB drive I had laying around was a 2GB one, so most ISOs turned out to be too big. XFCE fitted nicely, though. I had to wrestle my BIOS in order to get it to boot from USB, but eventually I succeeded. I must say, I’m impressed with the XFCE edition so far, even though I’ve mainly used it to select an older snapshot through the Snapper tool.
This has been the third time in more than three years that I really needed to rollback, and just like the previous times, it worked like charm. So I’m a happy camper again, and will wait a bit before running garuda-update. I suspect this issue is related to the Gnome 48 update. However, I’m also running the Garuda Gnome edition on my private laptop, and that one is still fine. Perhaps it’s some sort of driver issue, and Asus Zenbooks are a better match than HP ZBooks? ![]()
This concludes my Ted Talk, thanks for listening
